Oil in coolant reservoir
Old Aug 10, 2013 | 11:51 AM
jcfontario's Avatar
Default Oil in coolant reservoir
I have a 2000 Acura EL (same engine as Honda Civic), with about 200,000 miles. I have been losing oil lately and have discovered oil in coolant reservoir bottle and some in the rad itself. I have read many of the threads about this type of problem generally pointing to either a cracked block or a leaking head gasket but most folks who have had these problems also report a loss in power or engine overheating. I am not seeing either of these symptoms.
Can I have a cracked block or leaking head gasket without seeing overheating. Just debating whether to sink any more money into this car or to put it to rest and get something new.
Thanks
Old Aug 10, 2013 | 01:07 PM
Former User's Avatar
Default Re: Oil in coolant reservoir
The head gasket is almost surely blown.
Old Aug 11, 2013 | 03:07 PM
94EG8's Avatar
Seagull Management
Originally Posted by jcfontario
Can I have a cracked block or leaking head gasket without seeing overheating?
Yes. That happens frequently.
If you replace the headgasket make sure you also replace the thermostat, rad cap and waterpump, throughly flush the cooling system first as the oil in it swells anything rubber.
98civc123
23
Sep 8, 2021 08:14 PM
EdSales
Apr 29, 2010 10:14 AM
dc2_dude
Feb 13, 2009 12:12 AM
2wheelhunter
11
Mar 9, 2008 10:31 PM
dwc7276
Jan 28, 2007 12:42 AM
