D16Z6 Swap has knocking noise. Need Help!!!!!
Old Aug 9, 2013 | 12:51 PM
Evolutionjuan's Avatar
Icon2 D16Z6 Swap has knocking noise. Need Help!!!!!
Hey I recently swapped motors from a d15b which had its own issues (which are in my other posts)to a d16z6. After I swapped the z6 into the car and with the correct ecu I started the motor but only to hear what sounds like a knocking noise. I made sure the car had enough engine oil and coolant. I will try to post a video on here later or if not will post the video on my youtube account and will post the url here so you guys can look and here it. What is weird is that I drove the car and like the noise gets louder as I accelerate but at one point the noise went away. I checked the timing and its off a bit but I can not adjust it because I can not turn the dizzy the way I want it anymore. I recently bought a feeler gauge and going to do a valve adjustment and set the timing correctly (timing first though). The motor has no idling issues it stays at around 600-800. Does not fluctuate, when I was driving it around the block I felt the power difference compared to my d15b. Another thing that is weird is that the car does not overheat but I feel the heat of the motor and hoses get hot.
D16z6 info:
-Bought complete motor and tranny including dizzy,intake,sensors. (except for some hoses, I just swapped from my d15b.)
-Put new coolant in
-Did a oil change (Mobil 1 10W-40 fully synth as recommended by a lot of my friends who have z6's).
-Did not replace water pump (was just wanting to put in motor to see how it runs).
-Will replace thermostat
-Timing is off but by a little bit. To give u a better idea the 3 lings III you use to align with the V looking thing the 3rd line III<---- is aligned with the V.
-Car does not smoke or smell went a drive.
-Idles great
The Video is below of the noise im talking about...
http://s589.photobucket.com/albums/s...psb36d4fde.mp4
Old Aug 9, 2013 | 04:41 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default Re: D16Z6 Swap has knocking noise. Need Help!!!!!
Doesn't sound too crazy bad, Sounds re-build-able if you don't drive it anymore.
Old Aug 10, 2013 | 07:10 PM
VegasInvasion's Avatar
I'm Huge In Japan
threw a rod bearing, stop driving it and pull the pan.
Old Aug 10, 2013 | 08:37 PM
Thanks for the replies. VegasInvasion: do you know any DIY's on how to replace rod bearing? Ima do a valve adjustment tomorrow and then record if noise changes.
Old Aug 11, 2013 | 09:15 AM
No-Traction = Fun
Too bad you were not closer, id say bring it to me and I'll rebuild it for you (fair price)
Those are pretty easy. Also my machine shop is literally down the street from me.
Old Aug 15, 2013 | 11:19 PM
CaliforniaDad: What city are you in? What would the price be? message me in private if you want.
Old Aug 17, 2013 | 12:08 AM
I'm Huge In Japan
Haynes manual is pretty thorough, I rebuilt plenty of engines on them.
But they suggest removing the engine, all you have to do is drop the oil pan and crank girdle, unbolt the rod ends and pop some new ones in as you rotate the crank. Make sure to follow proper lube/torque procedures and cap the rod studs so you don't scratch anything up. for a noob it'll take a full day since you need to be extra careful.
Old Aug 18, 2013 | 01:47 PM
No-Traction = Fun
Im located in Hesperia, 92345
You can text or call me David 760-550-7997
Old Aug 18, 2013 | 10:21 PM
So I dont think its a rod knocking, I grabbed a long metal tube and put it on the block from one side and the other side to my ear and I dont hear any knocking coming from the block, I put the end of the tube in the slave cylinder housing and I hear the knocking noise like crazy, if I go back towards the block it gets quiter almost goes away. So here is what I think it is, its either one of the bearings from the throw out, or flywheel, or the shaft bearing on the tranny or whatever it is called. A older gentleman stopped by and checked out my motor because he has the same one and had a rod knock in his and the first thing he says when I start the car is that my motor sounds good but the noise is coming from the tranny sides not the motor. He said that a rod knock would be a different noise.
Tocco215
Aug 12, 2014 06:52 PM
GoldenLeg13
23
Mar 3, 2013 11:55 AM
k5egg
13
Dec 29, 2010 04:51 PM
mario_a_05
Mar 10, 2010 02:34 PM
yaya
Mar 8, 2003 04:09 PM
