JDM B18C Swap wont start!! HELP!
Old Aug 9, 2013 | 10:28 AM
RonKeen's Avatar
Icon3 JDM B18C Swap wont start!! HELP!
I recently purchased a 2000 Civic SI with a full JDM B18C Swap, the car was hit in the rear and the front but mainly the rear. The radiator was bent in a little but nothing major, the car has been sitting for a year and was missing the distributor but i just put on a fresh dizzy from HMotors. Also she has a Chipped P28 not the stock Type-R Dizzy. I can get her to rumble but she wont turn over. i know the firing order is
3 4
1 2
4321 left to right
but for whatever reason she wont start! ive put in starter fluid and checked all of the fuses but to no avail, can anyone help?
Old Aug 9, 2013 | 10:32 AM
JuggerNaut-CTR's Avatar
Default Re: JDM B18C Swap wont start!! HELP!
Have you even checked to see if it is in fact getting spark?
Checked all grounds are intact?
Checked if its getting fuel?
Main relay good? Hear the fuel pump priming?
Car has power from battery?
And....what does this even mean?
Old Aug 9, 2013 | 10:42 AM
ek sedan love's Avatar
Yup i agree with JuggerNaut-CTR all he says are the problems your engine wont start..
And yup check your coil for sparks!!
Old Aug 9, 2013 | 10:43 AM
RonKeen's Avatar
Plugs and Wires are good, grounds good, fuels good and the main relay is good, and ive used 2 batteries one that came out of a running 00 civic and the other was charged to full.
Old Aug 9, 2013 | 10:44 AM
RonKeen's Avatar
coils good
Old Aug 9, 2013 | 10:47 AM
RonKeen's Avatar
these are all things i checked after i put on the distributor
Old Aug 9, 2013 | 10:49 AM
grumblemarc's Avatar
The Grumpiest
What does "good" mean. What tests did you run to find this out?
Old Aug 9, 2013 | 10:54 AM
Still wondering what a type-r dizzy is?
Same distributor on other obd-alike dohc vtec motors...
Old Aug 9, 2013 | 11:00 AM
The Grumpiest
Maybe he meant ECU?
CaseyB
Nov 16, 2012 06:03 AM
LilKrnThugBoi253
Jun 23, 2006 09:17 AM
delphi-dada
Apr 5, 2005 04:09 AM
94RedEGCoupe
Apr 23, 2004 06:58 AM
