92 civic burning oil and smell
Old Aug 8, 2013 | 10:21 PM
Gatschet's Avatar
Default 92 civic burning oil and smell
Hey HT. I have a 92 civic ex sedan and when I accelerate quickly I get an oil smell and I was told some smoke comes out of my exhaust. It also burns a lot of oil, I always have to put some in it. What problems could it be and how would I start diagnosing them?
--- edit
143k miles on stock d15 approx
Old Aug 8, 2013 | 10:23 PM
jahong16's Avatar
Default Re: 92 civic burning oil and smell
Your motor is shot, replace it or rebuild it.
Old Aug 8, 2013 | 10:28 PM
Gatschet's Avatar
Really? I mean it really runs fine and fast besides the fact. Oh well, at least d15's are cheap and abundant
Old Aug 9, 2013 | 02:38 AM
jbpnoman's Avatar
Don't bother replacing it. You can do an OEM-spec rebuild yourself for a lot cheaper than a good quality engine will cost you. The constant oil loss sounds like failing piston rings, or a leak. The burning at high RPMs sounds like a valve stem seals. If you go the work yourself, replace the rings, bearings, valve stem seals, all gaskets, main studs, timing belt, water pump, and tensioner, have the block honed, and have the block and head both hydrosonically cleaned, and you can get it done and have a freshly rebuilt, 0 mile motor, for about the price of a "good quality" motor you might buy. I say "good quality" because you won't actually know until you put it in and turn the key, and by that point it's a crapshoot.
Old Aug 9, 2013 | 06:42 AM
jahong16's Avatar
rebuilding is probably the best bet, most d15s you can find are pretty shot too and if you get another motor might as well get a d16. But, your cylinder walls probably scratches in them letting the oild slip into the combustion chamber, by your description, alot too. it can also leak through the valve stems. you most likely will have to bore oversize. and all the thigs listed above is basically everything needed for a rebuild.
Old Aug 9, 2013 | 06:51 AM
AFH-Parts's Avatar
Don't let the oversized bore terrify you OP, that's standardized rebuilding procedure. Honda sells 0.25" over rings for rebuilds.
Old Aug 9, 2013 | 01:33 PM
Gatschet's Avatar
Thanks for all the info! I'll definitely start saving to rebuild
Old Aug 9, 2013 | 01:41 PM
b20bFourDoorCivicLX's Avatar
Rebuild for sure. GL some pictures of the progress would be nice.
Old Aug 9, 2013 | 09:42 PM
Gatschet's Avatar
It'll be a long time away, but I'll definitely be posting when I do. Its just that I really need daily transportation. The most days in a row I'd have off is 4. Maybe, if I can get motivated, I can buy a b18/b20 swap and rebuild that while still using the d15 then swap it out in a couple days and be good to go. Would doing that be too costly? I want the power but I always planned a bigger swap down the road, but hey, if I have to swap why not go big?
Old Aug 10, 2013 | 06:37 AM
crazyhouse2011's Avatar
So if they bore it out 0.25 over, it will increase the displacement almost to a 1.7?
Old Aug 10, 2013 | 10:06 AM
gabriel0830's Avatar
yup definitely sounds like piston happn to my D15b also blowing out white and than black smoke soon the piston jus snapped but def jus save up for a rebuild much cheaper or save up enough and jus swap a new motor
Old Aug 10, 2013 | 10:23 AM
Root16's Avatar
Yup, definitely sounds like piston. Happn to my D15b: also blowing out white and than black smoke. Soon the piston jus snapped. But def jus save up for a rebuild, much cheaper. Or save up enough and jus swap a new motor.
Grammar. It is your friend.
Old Aug 10, 2013 | 11:47 AM
AFH-Parts's Avatar
No. It probably won't even be enough to bump you into the 1.6 range. You have to remember that displacement is calculated by bore x stroke. It's going to make little to no impact on overall displacement of the engine.
Old Aug 10, 2013 | 12:41 PM
jbpnoman's Avatar
A 92 EX should have a D16Z6.
75mm bore, 95mm stroke gives 1590.5cc displacement
75.25mm bore, 95mm stroke gives 1601.1cc displacement
lsvtechatchy
Apr 4, 2011 09:10 AM
Spectrum_16
Mar 6, 2007 05:23 PM
Yankee
Oct 27, 2004 07:23 AM
drdavid
Mar 19, 2004 11:59 AM
djmacani
Oct 2, 2003 06:20 AM
