b16 engine swap exhaust
Old Aug 8, 2013 | 07:34 PM
tyb's Avatar
tyb
Default b16 engine swap exhaust
i will be swapping a b16 in in a while
i would like to know if the DC Sports Header for 99-00 Civic SI bolt up to an Apexi WS2 Catback designed for a 92-00 civic ex/si.
i am in california and needs to be smog legal that's why dc sports.
thanks for your input and it will be a 96-98 civic ex coupe and the swap will be the SiR-II b16 from hmotors.
thanks!
Old Aug 8, 2013 | 10:29 PM
B_Swapped93's Avatar
Default Re: b16 engine swap exhaust
Depends on the cat's length as that's the "joiner" between the two.
Old Aug 9, 2013 | 12:24 AM
Hmong EM1's Avatar
10 Year Member
yea it bolt up if you use your ex catalytic converter in between the header and catback.
Old Aug 9, 2013 | 06:02 AM
tyb's Avatar
tyb
Well here in California I'm pretty sure we have to use the emissions system of the engine we are swapping in so it could be an SI catalytic converter. Will a header made for 99-00 SI work with a 96-98 b16 from hmotorsonline?
So I'm thinking
Apexi WS2 exhaust catback
DC Sports CARB Legal Header made for 99-00 SI
Old Aug 9, 2013 | 06:10 AM
grumblemarc's Avatar
The Grumpiest
What's an SI catalytic converter? Are you making this stuff up?
Old Aug 9, 2013 | 11:28 AM
tyb's Avatar
tyb
A D16 Catalytic Converter will not be effective to anything other than a d series. Here in California, we have to replace the catalytic converter with a stock or CARB legal catalytic converter for the engine we are putting in our cars.
So for example...
Stock D16 catalytic converter won't work with a B16
Stock B16 catalytic converter won't work with a D16
The Honda Civic or DEL SOL SI has a B16A2. They use a catalytic converter designed for a B16A2 engine. Hence why I said I might buy a stock Del SOL SI or CIVIC SI catalytic converter.
Old Aug 9, 2013 | 11:54 AM
rico58204's Avatar
Del Sol vtec has b16 in it
Del Sol SI has a d16 in it
Old Aug 9, 2013 | 11:55 AM
tyb's Avatar
tyb
oh s*** wtf why wouldnt the si have the better engine?
anyway i know the civic si has B16
Old Aug 9, 2013 | 03:12 PM
Hmong EM1's Avatar
10 Year Member
the ex and si cat are the same
tronic
Jan 7, 2011 07:37 PM
hondaZvic
Sep 30, 2010 08:47 AM
Type-R32
Aug 10, 2008 09:52 PM
domscivic
May 2, 2008 11:04 PM
Hulkster2k3
May 18, 2005 10:40 PM
