94 civic ac debacle
Old Aug 8, 2013 | 03:27 PM
Romach's Avatar
Icon2 94 civic ac debacle
94 civic cools @ 55mph, any slower none. some history: replaced discharge line that was leaking, compressor seems to be working, replaced expansion valve, and dryer filter. evacuated the system (drew vac. for 2hr. @ 30in. ) recharged with oil and 1.5 lbs. r134. not cold. performance tested system. rpm1500+, ac full on, windows open. used fan at front of car for added cooling. 10+ min. running. gage readings were: low side 55 to 60 (above norm.) high side 155 to 160 (below norm.) after shutting ac off, gages read 55 low side 120 high side. I suspect the compressor is failing. any help welcome.
Old Aug 8, 2013 | 04:17 PM
Former User's Avatar
Default Re: 94 civic ac debacle
Outside temp during performance test?
Are the condenser fins clogged with road debris? Does the condenser fan run?
But yeah, at this early juncture, it does sound like the compressor may be toast.
Old Aug 8, 2013 | 04:22 PM
fleabag's Avatar
if you're sitting in your car idling, the cooling system doesn't work but if you rev the engine while stationary to 3K, does it cool? Slipping clutch perhaps?
Old Aug 8, 2013 | 05:31 PM
Romach's Avatar
Outside temp was 78degrees, humidity aprx. 60%. Condenser fins look clear, condenser fan is working well. I did tighten drive belt some, but this made no difference.
Old Aug 8, 2013 | 05:33 PM
Romach's Avatar
at sitting still, no cooling at any rpm
Yeah, I think your compressor is toast.
oaklandwilly
Honda Civic (2006 - 2015)
Jun 27, 2018 08:17 AM
hillbillycivic
Jul 7, 2013 09:22 PM
Roddogz28
Jul 1, 2013 10:17 AM
fixmyac
Jan 26, 2012 11:59 PM
94LS_allmota
Jul 24, 2009 06:06 PM
