Another 5 speed swap question
Old Aug 8, 2013 | 02:34 PM
Dan_Brutal's Avatar
Default Another 5 speed swap question
I have a 98 hatch and I'm planning on a 5 speed swap. I have everything except the mounts. I have read a ton of different treads saying you need this and that, and some say the auto mounts will work. My question to you guys is this: what mounts do I need? Which tranny brackets to I need? The tranny I picked up is a P20 A000 out of an eg. It came with the upper bracket and mount. Is that usable in my 98? Any help is greatly appreciated.
Old Aug 8, 2013 | 02:37 PM
ManTyme's Avatar
Default Re: Another 5 speed swap question
you can use the transmission from an eg.
you can use the stock mounts but you will need the 5 speed brackets for the transmission (rear and pass side)
are you doing a single cam or dohc swap?
if its a single cam or b16 you can use the stock driver bracket.
if ls or gsr you need an aftermarket mount and bracket
edit:your doing an auto to manual swap correct? do you have all the wiring down packed? if not i can direct you towards a link
ferio-ichi3's Avatar
Ferio Wdm Edition
Yes, the auto tranny mount will not work, use the mount that came with the tranny you picked up
Old Aug 8, 2013 | 02:40 PM
Dan_Brutal's Avatar
Thanks for the quick replies guys. I have a y7(sohc love). So, all the auto mounts will work, I will just need to pick up a 5 speed t bracket and lower side bracket?
Old Aug 8, 2013 | 02:41 PM
teamXteg's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/auto-5-speed-swap-completed-dos-donts-56k-go-do-oil-change-come-back-seri-550221/
^^ here is a couple write ups on it man its in the sticky FAQ.. check it out lots of info! good luck!
Old Aug 8, 2013 | 02:42 PM
ManTyme's Avatar
this will be a huge help. it helped me with my first auto to manual conversion. now they are a walk in the park
Old Aug 8, 2013 | 03:52 PM
94EG8's Avatar
Seagull Management
You need the upper transmission bracket from a '96 - '00 Civic along with the rubber upper transmission mount, rear mount and lower torque mounts. Technically you could reuse the rubber automatic mounts if you really wanted to, but they're weaker than the manual mounts.
Old Aug 8, 2013 | 05:58 PM
Dan_Brutal's Avatar
Will this stuff take care of the mounts and brackets?
http://www.ebay.com/itm/Honda-Civic-Motor-Engine-Mount-Kit-96-00-D16Y8-D16Y7-EX-DX-CX-LX-/290954779973?pt=Motors_Car_Truck_Parts_Accessories&hash=item43be419d45&vxp=mtr
http://www.ebay.com/itm/96-97-98-99-00-HONDA-CIVIC-REAR-ENGINE-MOTOR-MOUNT-BRACKET-OEM-/281124811229?pt=Motors_Car_Truck_Parts_Accessories&hash=item41745831dd&vxp=mtr
http://www.ebay.com/itm/96-97-Honda-Del-Sol-OEM-side-transmission-mount-bracket-D16y8-MT-/200780889922?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ebf793f42&vxp=mtr
Old Aug 9, 2013 | 02:14 AM
94EG8's Avatar
Seagull Management
No, the upper mount pictured is for a '92 - '95. Also you don't need the rear bracket as both the automatic and manual are the same.
turboblack2door
Oct 8, 2012 03:10 PM
xxEG6xx
11
Apr 24, 2011 03:54 PM
turbo_sohc
Jul 31, 2006 09:49 AM
allmotor.net
Nov 24, 2003 04:08 AM
chirp3rd
Jun 24, 2002 06:13 AM
