AEM,RC,BDL,HONDATA,Turbo Part out!
All parts are located in Atlanta,GA
text 404-987-7284
Car: 1996 Honda Civic Cx Hatchback
Uploaded with ImageShack.us
[IMG=http://imageshack.us/a/img33/2720/6yag.jpg][/IMG]
D16z6 Block:
$700
Eagle rods
Overbore to 76mm
ycp pistons 9.1
ACL bearing kit
ARP Head Bolts
D16z6 Head:
$600
Bisimotto 2.4 turbo Cam
Brain Crower Springs and retainers
AEM Cam Gear
Elerbrock performer X Intake Manifold $250.00
Skunk2 PRO 70mm Throttle Body $160.00
Catch can setup with two SS line and Vented VC $220
Transmission:
Stock Transmission 5 speed w/ linkage $250
Stage 4 Clutch $100
Fuel System:
Walbro 255 Fuel Pump $60
Russell Fuel filter kit $200
BDL Fuel rail $100
Engine Management:
Hondata S300 with boost solenoid in a P28 $600.00 or $550.00 w/o Solenoid.
OBD1-Obd2a jumper harness $50.00
Turbo Setup:
Garret 70 trim w/ 3" V band exhaust dp $600
44mm Tial Wastegate w/ 2.25 V Band dump tube $300.00
CX Racing Front mount intercooler & Piping 2.5" $200.00
SPA Cast Iron Top Mount Manifold $120.00
HKS Sq3 Blow off Valve $180.00
RC 750cc Injectors $275.00
Suspension / Wheels / Brakes
5 (5.114) lug suspension from an EK9
Drilled & slotted Rotor all the way around $1200.00
Ap1 wheels 1 full set with 90% tires. $400
Also have a set of brand new drag radials 255/50/16's $250
Skunk2 Front Camber Kit $80
Skunk2 Adjustable lowering springs $100
Blox black extended lug nuts $50.00
Ebay Rear Camber Kit $30.00
Blox Lower control arms (gold) $60.00
Exterior & Bay
2000 SI front end $200
CF Hood 99-00 $350.00
Type R Spoiler $140.00
Front end is black, rest of car is white.
Bay is completely shaved and painted gloss black and cleared.
Interior:
02 Rsx front and rear black leather seats. $400.00
Ap1 s2000 steering wheel $140.00
Red suede wrapped headliner $50.00
Has rear cargo cover $60.00
Custom Gauge holder $40.00
Radio relocated to center console
Fuse box relocated in Glove box
Battery located in trunk
AEM DIGITAL GAUGES:
BOOST WITH SENSOR $150
WIDEBAND WITH SENSOR $180
OIL PRESSURE WITH SENSOR $180
text 404-987-7284
D16z6 Block:
$700
Eagle rods
Overbore to 76mm
ycp pistons 9.1
ACL bearing kit
ARP Head Bolts
D16z6 Head:
$600
AEM Cam Gear
Transmission:
Stage 4 Clutch $100
Fuel System:
BDL Fuel rail $100
Engine Management:
Turbo Setup:
Exterior & Bay
Interior:
AEM DIGITAL GAUGES:
PARTS LEFT!
D16z6 Head:
$600
AEM Cam Gear
Turbo Setup:
Interior:
D16z6 Head:
$600
AEM Cam Gear
Turbo Setup:
Interior:
glennsek
Aug 21, 2013 01:44 PM
