VTEC Controller? 1999 honda accord lx f23a1
Just out of curiosity, what modifications have you made to your engine to warrant a shift in VTEC engagement?
What controllers have you used in the past that put your engine into limp mode?
There is the AEM F/IC 6. It shouldn't throw your car into limp mode, as long as it is hooked up correctly.
To be honest with you. If you have not done anything significant to the engine. I.E. upgraded camshaft or internal components. Then changing the VTEC engagement point isn't going to give you much of a gain. If anything it will probably give you a flat spot in your power curve....
rockercris50
Oct 8, 2013 09:42 AM
