EF hatch TDC code
Old Aug 7, 2013 | 09:25 PM
JuneBugDrfter's Avatar
Default EF hatch TDC code
hey i recently blew up my 14:1 compression minime and swapped a d15b6 i had lying around into my ef. thing is i get TDC codes all the time. Im using a obd1 distrubitor bc my obd0 distributor is rotted all to hell.
Old Aug 7, 2013 | 10:39 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: EF hatch TDC code
Is your ECU OBD1 as well?
Old Aug 8, 2013 | 05:28 AM
no my ecu is obd0 and could it be that my pm5 computer is not capable of knowing TDC on a hf block
Old Aug 8, 2013 | 08:32 AM
24TEN's Avatar
PHANTOM MENACE
The block is irrelevant. It's the way the ECU interprets the signals from the distributor. I believe that your specific problem is two fold:
1) Wrong distributor/ECU combination. DPFI distributor is different from a MPFI distributor with respect to it's corresponding ECU. The MPFI distributor has an extra sensor.
2) OBD mismatch. You have an OBD0 ECU and an OBD1 distributor. Aside from the ECU being DPFI the disconnect is in the way it interprets the signals coming from the distributor.
It's a bit more complicated than that, but that is basically what is happening.
Old Aug 8, 2013 | 12:39 PM
So I need to find the distributor for my Ecu. My crx has the td01u. Distributor. 437 bucks brand new 220 remanufactured. That's expensive compared to other parts. I have no junkyard around that carries my car. Rare breed of honda
Timothy Yhtomit
Jan 28, 2019 10:49 AM
89hatcher
Jun 5, 2006 02:01 AM
dalepatters
Oct 28, 2003 02:55 PM
foesicks
Sep 8, 2003 09:47 AM
