Rear Hub/Disc brakes
Old Aug 7, 2013 | 06:11 PM
hmoobvwj's Avatar
Default Rear Hub/Disc brakes
Alright so my rear disc bearings are going out. Never done this before but was suggested a few things from different people.
Replace bearing and most say just buy new hub assembly. I am thinking of just buying 2 new hub assembly with bearings, studs, etc.. Now I am stuck on which brand? From my research I hear oem is made by NTN and/or KOYO. Anyone have experience from either or know any information..
Last, any DIY on how to do so..
Thanks!
Old Aug 8, 2013 | 06:22 AM
cvcrcr99's Avatar
Default Re: Rear Hub/Disc brakes
I have a set on Timkens on my car and have had no problems for 6+ months. Bought them off rockauto.com
Raise car, remove wheels, brake caliper, brake caliper bracket, rotor, then rear axle nut (easiest to loosen when car is on the ground). Hub should come right off at that point Then put everything back together.
Old Aug 8, 2013 | 07:59 AM
hmoobvwj's Avatar
Thanks for the info, Timken was an option for me too. Yeah I am looking at rockauto and partsgeek
Old Aug 8, 2013 | 08:00 AM
Fliptard's Avatar
I bought a set of Ebay for both rear hubs and bearings, was like $50ish and have had no issues with them. Don't remember what brand/company it was tho.
Old Aug 8, 2013 | 08:47 AM
hmoobvwj's Avatar
Alright, thanks
Old Aug 8, 2013 | 09:53 AM
ek4serge's Avatar
Oem????
Old Aug 8, 2013 | 03:47 PM
Calif_Kid's Avatar
I've got a 2000 Civic hatch race car, and just replaced both rear hubs (Koyo approx $125 each) plus installed new 22mm spindle nuts. I think you'll need a 32mm socket for the spindle nuts, and the install torque I used per the manual was 134 ft-lbs. If you've got rear disks, then it will be good time to double check the slider pins - I hadn't lubed them when I replaced the rear pads previously, but I relubed them when I replaced the rear hubs. - Jim
Old Aug 8, 2013 | 03:57 PM
crazyhouse2011's Avatar
Old Aug 8, 2013 | 04:06 PM
Calif_Kid's Avatar
crazyhouse - I mentioned that it is a race car to justify why I went with a good quality / OEM hub unit. I could have gotten a generic brand a lot cheaper on E-bay, but I really would rather not have any problems on the track. - Jim
Old Aug 8, 2013 | 04:35 PM
hmoobvwj's Avatar
Thanks for the info and feed backs. I am most likely going to get koyo hubs and will def check the slider pins.
Old Aug 9, 2013 | 03:04 AM
Fliptard's Avatar
no, mine are not OEM ones.
Old Aug 9, 2013 | 10:52 AM
hmoobvwj's Avatar
From experience and/or knowledge which one?
KOYO OR NTN
grumblemarc's Avatar
The Grumpiest
From a Google search, which one?
Old Aug 9, 2013 | 01:55 PM
hmoobvwj's Avatar
Its a 50/50 because people are saying both brands are oem. the one thing that stood out and I am not 100% is ntn is used for honda f1 racing, etc..
Old Aug 9, 2013 | 05:17 PM
94EG8's Avatar
Seagull Management
NTN was the OEM manufacturer. Also, for what it's worth you have to buy the whole hub assembly, you can't get just the bearing for the rear.
Old Aug 10, 2013 | 03:50 PM
hmoobvwj's Avatar
Yeah I know I have to get the whole new hub. I am most likely planning to get NTN hub assembly.
Thanks to everyone who helped!
hmoobvwj
Suspension & Brakes
Aug 19, 2013 02:12 PM
eg:R
10
Oct 15, 2011 02:15 PM
akteamster
Suspension & Brakes
Nov 22, 2005 07:54 PM
jason_alt
Nov 21, 2004 10:14 AM
Tiamat-blue
Aug 19, 2002 08:10 AM
