Which distributors fit 1991 ED7 D16A9?
Old Aug 7, 2013 | 10:18 AM
Victor Jónsson's Avatar
Default Which distributors fit 1991 ED7 D16A9?
Hi there peeps.
Searching the net I can't really figure out which distributor fits my i1.6 DOHC D16A9 engine. As example D16A1 and a others from the D16A* line might be usable. But again this is a DOHC.
I this engine the same as the one called JDM ZC?
Also I've read something about a Acura Integra distributor that fits. Fits meaning: exactly the same / drop in replacement
Also I've found this list: (unfortunately I don't have the url. I copied the list)
  • [TD-01] Civic/CRX DPFI 1988-1991
  • [TD-02] Civic/CRX MPFI 1988-1991
  • [TD-03] OBD0 DOHC ZC Civic/CRX 1988-1991
  • [TD-22] OBD0 B16 Civic/CRX/XSi 1988-1991
  • [TD-23] OBD0 B18a Integra 1990-1991
  • [TD-31] Accord 1990-1991
  • [TD-41] Civic D15b Non-VTEC 1992-1995
  • [TD-42] d16z6/d15b VTEC 1992-1995
  • [TD-43] OBD1 DOHC ZC 1992-1995
  • [TD-44] OBD1 B16/GSR/ITR VTEC 1992-1995
  • [TD-46] OBD1 b18a/LS/B20/CRV 1992-1995
  • [TD-52] Accord 1992-1993
  • [TD-55] OBD1 b18a/LS/B20/CRV 1992-1995
  • [TD-60] Prelude H22a 1992-1996 JDM
  • [TD-63] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
  • [TD-68] OBD1 B16/GSR/ITR VTEC 1992-1995
  • [TD-73] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
  • [TD-84] OBD2 B16/GSR/ITR VTEC 1996-2001
  • [TD-89U] Prelude H22a 1997-2001 JDM
It seems to me that I need TD-03. But if some of the others can be used because they're the same, I'd really like to know.
I need to go hunting for a new distributor.
Thanks for the help.
- Victor
Old Aug 7, 2013 | 12:13 PM
jlicrx's Avatar
Default Re: Which distributors fit 1991 ED7 D16A9?
the 88-91 JDM DOHC ZC, the 88-89 USDM Integra D16A1, the EDM D16A8/A9 distributors all fit - nothing else - they are TD-03U
Old Apr 22, 2016 | 04:21 AM
YashR1's Avatar
Even if one is dohc and other sohc??
Old Apr 23, 2016 | 07:26 AM
jlicrx's Avatar
all of the engines listed above are DOHC, all use the same distributor and only the TD03U distributor fits - no SOHC distributor will fit
I should add that the EDM D16Z5 also uses the same distributor - it is also DOHC, basically the same as the D16A8/A9
luis.vera45
Feb 11, 2014 05:28 AM
Canadian_EF
10
Aug 26, 2009 06:52 AM
freshly boosted DOHC ZC
Jan 12, 2007 11:50 AM
97grnrs
Dec 10, 2006 04:14 PM
1990hondaHF
Oct 8, 2002 08:38 AM
