98 Civic ex AC issues
Old Aug 7, 2013 | 05:21 AM
zmnypit's Avatar
Default 98 Civic ex AC issues
Long story short I put a new motor in my wife's civic ex then recharged the AC using 2 cans of r134a. Works great when you stay around 55mph or lower. When your on the interstate the AC seems to blow cold for a min then hot. So its basically off and on. I had the system vacuumed two days ago and it pulled -22psi so I know there's no leak. After having it vacuumed I re-charged with two 12oz cans (book calls for 22oz) and same deal. Off and on off and on. Has anyone experienced this? If so was there a solution.
Condenser fan is running. Pressure was around 200psi on the high side if I remember correctly looking at the gauges when vacuumed.
Old Aug 7, 2013 | 06:18 AM
Former User's Avatar
Default Re: 98 Civic ex AC issues
You overcharged the system with refrigerant. You need to add refrigerant by weight using a scale and not rely on amount stamped on the can.
Old Aug 7, 2013 | 06:42 AM
zmnypit's Avatar
If it was overcharged would the low side pressure be more than 42-45psi I'm getting now? I tried with 1.5 cans and got the same result except it never really got cold.
Old Aug 7, 2013 | 06:51 AM
A low side refrigerant pressure alone is not very informative. Other conditions must be included, such as high side pressure, outside temp and humidity, engine rpm, A/C setting, and air temp output from vent.
Below is the proper way to performance test your A/C system. In step 1, you obviously would hook up a manifold gauge set rather than a professional charging station.
Old Aug 7, 2013 | 07:10 AM
Here's something else to consider.
You did not pull a deep vacuum, which is about -30 PSI. Therefore, there's likely air and moisture in the system. In addition, did you replace the receiver/dryer just prior to evacuating and recharging the system?
Old Aug 7, 2013 | 09:19 AM
zmnypit's Avatar
I let the pump stay on for a good 15min once it reached -22psi. Guess its possible the gauge was bad. I did not replace the dryer.
Old Aug 7, 2013 | 09:40 AM
It's clear from your posts that you should:
  1. Recover the refrigerant
  2. Replace the receiver/dryer
  3. Pull a deep vacuum (about -29 PSI) and leak check
  4. Recharge system with the proper refrigerant weight and oil volume
  5. Performance test system as per diagrams I posted.
Old Aug 8, 2013 | 09:51 AM
Del Solid's Avatar
that's at sea level:
http://www.anver.com/document/vacuum...20pressure.htm
still looks like he didn't attain an adequate vacuum. but he may never be able to reach 29 or 30"Hg if he's at altitude. use a can of R-134 with UV dye and a UV light to help find any leaks. one of my used hoses leaked at the compressor.
Old Aug 8, 2013 | 10:06 AM
tony_2018's Avatar
Fish Twig
Yeah you didn't pull a good vac. Try to find another set of gauges and vac and do another pull to be sure. -22 is still not good enough. I know I get -32 or so when I was living in Louisiana. What I usually do is let it pull a vac for 15 minutes and then close off both valves with the ***** on the gauges and wait to see if pressure rises. If it does than you have a leak.
Old Aug 8, 2013 | 10:43 AM
ek4serge's Avatar
X2 great post
Old Aug 14, 2013 | 02:50 PM
zmnypit's Avatar
Replaced the drier and Had the system vacuumed again to -27psi and left it over night. Still had a vacuum on it next day. Added one can of r134a and showed around 47psi on the low side at idle so I left it alone and took it for a test drive. All was well and didn't cut off in 15min of driving. Hit the Interstate and after about 10min it started blowing hot for a few secs the back cold for 5mi or so then back hot. Seems like the further I went the more frequently it would switch back and forth. When in the car I can't feel the compressor kick off. Any other suggestions?
Old Aug 14, 2013 | 05:33 PM
OrangeChrome's Avatar
High side pressure? Outside temp?
Old Aug 14, 2013 | 06:10 PM
zmnypit's Avatar
Not sure. I'm having to take it to a friends shop to vacuum and he has the gauges. I have a lowside gauge and when you rev the car over 2k rpm the pressure drops below 20psi
Old Aug 15, 2013 | 02:46 AM
strategy400's Avatar
Replace the receiver drier for sure. Its a PITA but worth it. Also the correct weight of charge is critical. Otherwise your gas will expand prior to or after the evaporator. But I vote for contamination with your intermittent cooling.
1.Recover the refrigerant
2.Replace the receiver/dryer
3.Pull a deep vacuum (about -29 PSI) and leak check
4.Recharge system with the proper refrigerant weight and oil volume
5.Performance test system as per diagrams I posted.
^rhis
Cmoya07
May 9, 2013 08:09 PM
REDEM1FTW
10
Mar 27, 2012 10:19 PM
PsychoCam
Honda Civic (2001 - 2005)
10
May 30, 2011 08:25 AM
technine
31
Jun 27, 2007 11:45 AM
