D16y7 Automatic Transmisson, HIGH RPMs on highway?
Old Aug 6, 2013 | 11:34 AM
SkyliteCustomz's Avatar
Default D16y7 Automatic Transmisson, HIGH RPMs on highway?
Haven't posted here in years, back into the Honda Scene now . long story short, I have a 1997 Honda Civic LX (auto). At 70mph my RPMs are between 3,000-3,500. Is this normal? Can anyone with an automatic transmission 96-00 Civic chime in? Thanks in advance.
Old Aug 6, 2013 | 12:18 PM
OrangeChrome's Avatar
Default Re: D16y7 Automatic Transmisson, HIGH RPMs on highway?
I sit at like 3100rpm @ 70mph in a 5 speed y7/y8 mini me, so that sounds about right.
Old Aug 6, 2013 | 12:31 PM
strategy400's Avatar
Its close to right. Maybe your torque converter isn't going into lockup mode? That'll lower your RPMs about 300 and save a little fuel. You should be able to see (if you have a tach) or feel it go into lockup mode.
These engines love to rev.
Old Aug 6, 2013 | 12:45 PM
Car is equipped with a Tach (ex cluster) . Im new to Auto Tranmissions. How would i feel it go into lock up mode? Yea the engine loves to rev, torqueless wonder lol thanks for the response.
Old Aug 6, 2013 | 12:47 PM
Transmission isn't slipping though, that much i know. Just wondering why its at such a high rpm (maybe its just me being OCD?) Lol. When I had a b16 tranny, it was expected. So this automatic transmission kind of has me baffled.
Old Aug 6, 2013 | 01:06 PM
redcoats1976's Avatar
is your speedometer accurate?i checked mine with a GPS and discovered it was from 10-15 off at 70.fault was in the speedometer head.but yes,i didnt think my converter was locking up either.it turned out i was just going faster than i though.
Old Aug 6, 2013 | 05:07 PM
When the torque converter locks up or unlocks the RPM will go up or down about 300 RPM accordingly. Its to increase mpg.
Old Aug 6, 2013 | 07:04 PM
Laughing Man's Avatar
my 98 lx auto is around 3000rpm at 70mph.
Old Aug 6, 2013 | 07:31 PM
I have never really tried to gauge the speedometer with a GPS , but I shall try and see if I'm getting accurate readings.
Old Aug 6, 2013 | 07:32 PM
hmm..so this may be all be normal then, just seem like some high *** revs for highway driving.
Old Aug 7, 2013 | 05:00 AM
Update : was checking the calibration on my TPS yesterday and noticed my throttle cable had some slack. I readjusted it to a tighter spec, reset ecu and the problem seem to have went away. Will keep the thread updated in a couple days to see if everythings ok. Thanks for the input everyone.
Old Aug 8, 2013 | 04:23 PM
UPDATE : Car still is showing the same symptoms, but not all the time. I believe its not "locking up" at highway speeds, I already swapped out the lock up solenoid for one from a junk yard, still doesn't lock up. Any input/help/ideas?
Old Aug 8, 2013 | 04:27 PM
MAD_MIKE's Avatar
MM Gruppe B
Make sure your temp sensors are functioning correctly and no codes are stored.
Old Aug 8, 2013 | 05:18 PM
Car has no codes, Temperature is running at normal range.
Old Aug 9, 2013 | 07:26 AM
Chriser0's Avatar
The trans will lockup at about 55MPH. thats where mine does (same motor). it feels like another gear when it happens.
Old Aug 9, 2013 | 05:01 PM
tony_2018's Avatar
Fish Twig
My y7 tranny is 300rpm's less from 3000rpm when cruising at 70mph.
Old Aug 10, 2013 | 12:38 PM
Yea i think the problem is my lock up solenoid, sometimes it will lock up, sometimes it wont. No CELS or anything, i will research some more and update as necessary
hondacrx2
14
Jul 27, 2011 04:40 PM
20-EM2-05
Honda Civic (2001 - 2005)
May 7, 2009 10:01 PM
PhongT12
Nov 8, 2005 02:11 PM
pyrojeff
Mar 23, 2004 07:52 PM
bhcvc
May 22, 2002 11:18 AM
