EM1 OBD1/OBD2B help needed
Old Aug 5, 2013 | 09:18 PM
eM1_kiD's Avatar
Default EM1 OBD1/OBD2B help needed
what's up HT. I have a 2000 Civic Si with an 95 LS swap, why you may ask, because before it had a D16Y8. anyways, I finished the swap and everything. now the only problem is that it won't crank over. checked my grounds and everything, got the jumper harness for the ECU to run a P75. I got a jumper harness for the dizzy because I am running an OBD1 dizzy and an OBD2b harness. now the pins won't connect, I found out I have an EX harness which is the 8 pin plug, which won't fit. what should I do now? should also throw out there that my wire harness is insanely messed up, smh. thanks in advance.
Old Aug 6, 2013 | 09:31 AM
Marvin1985's Avatar
Default Re: EM1 OBD1/OBD2B help needed
Find a em1 harness. Scrap the old one
Old Aug 6, 2013 | 12:39 PM
ElPrimo509's Avatar
find a em1 or ex harness
Old Aug 6, 2013 | 07:19 PM
aavtec's Avatar
You need a obd2a to obd1 dizzy harness. The ex/dx dizzy plug changed from obd2a and obd2b but the si/hx plugs stayed the same.Get a 96-98 to obd1 dizzy harness
jdm_crazed
Jan 22, 2010 08:53 AM
accord2civic2prelude
Aug 14, 2009 05:42 AM
8YourV8
Jan 3, 2007 09:49 AM
