STD door weight? can I change doors?
Old Oct 25, 2002 | 06:38 AM
Audipwr1's Avatar
Default STD door weight? can I change doors?
The built in seatbelts into the door must make the door be extrememly heavy, now can I swap over to an si door?
what do you guys do to lightened up those doors!
(going to be for mostly track/A/x but still be rigged to be street legal
Old Oct 25, 2002 | 07:44 AM
USDM 4G VTEC's Avatar
Default Re: STD door weight? can I change doors? (Audipwr1)
i doint think the seat belts will add that much weight.. maybe 2-3 pnds.
not worht the big hassle
Old Oct 25, 2002 | 08:16 AM
Audipwr1's Avatar
Default Re: STD door weight? can I change doors? (JDM EF9)
the door itself looks heavily reinforced. It is a load bearing member since it must support the seatbelts
Old Oct 26, 2002 | 11:55 AM
crxjdmsir's Avatar
Default Re: STD door weight? can I change doors? (Matthew)
The doors can't be swapped as a whole but you could move the belts to the pillars and remove the crap from the doors. It still won't save you all that much weight. Structually the car is much stiffer than the 88's. The 89-91 had more reinforcments and bracing in the quarters, doors, and door frame. Not really worth it imo.
MR.johnson
Feb 2, 2013 08:07 AM
singlecamsaint
16
Mar 5, 2012 04:44 AM
CLK-EF
Sep 26, 2005 04:40 PM
Mentat Ghola
Mar 3, 2004 01:40 PM
PatrickGSR94
Feb 10, 2004 03:38 AM
