1998 honda accord 2.3 vtec help!!!!
Old Aug 4, 2013 | 08:40 PM
banegoks's Avatar
Icon6 1998 honda accord 2.3 vtec help!!!!
i just replace the engine on my Honda accord, the problems is that starts but when i press the gas goes to up to 2000 rpm and it looses power totally and it wants to shut off,no available to drive it yet, if i put it in drive the idle goes really down and no available to press gas at all, i replace spark plugs, cables, rotor, distributor cap, injectors, EGR valve, fuel pump and filter, knock sensor, throttle body, and it does the same !!!!!!!! i just want the car to run fine, please any ideas or comments of what i did or doing wrong ??? do u think maybe the torque converter is bad? no check engine light on at all.
Old Aug 5, 2013 | 12:19 AM
holmesnmanny's Avatar
Default Re: 1998 honda accord 2.3 vtec help!!!!
what engine did you replace it with ? If it was jdm did you swap over the crank timing pulley and the oil pump ?
don't just assume no codes because the check engine light isn't on...actually check for codes
Old Aug 6, 2013 | 08:16 AM
Lost Again's Avatar
What are the color of the three wires going to the MAP sendor?
Revenant_06
Aug 13, 2015 01:35 PM
Revenant_06
Aug 12, 2015 09:37 PM
TrevvTurnt23
Apr 29, 2015 10:07 AM
christina4733
Apr 16, 2014 07:01 AM
Honda MGR
Dec 23, 2013 01:06 PM
