91 ef hatch motor mounts help!!! PLEASE!!
Old Aug 4, 2013 | 02:32 PM
mskbjdm's Avatar
Default 91 ef hatch motor mounts help!!! PLEASE!!
Hey guys!
i had a fully built B20V on my 91 ef si.
now im going back to single cam.
can i use the same mounts i used on my B20v motor on my new Single cam? also i need an ECU, can i use the same one i used on my b20V swap"? or what ECU should i get? is my first time that i would be swaping a motor so it should be super FUN!
please let me know im planning on starting the swap tomorrow.
Thank You in Advance guys!
Sincerely
God Bless
Old Aug 4, 2013 | 09:12 PM
jonGSR's Avatar
Default Re: 91 ef hatch motor mounts help!!! PLEASE!!
No, you will need the d series mounts. Your ecu depends on which motor you are putting back into the car. More than likely it sounds like you will need a pm6.
91ef9bc
May 2, 2010 06:23 PM
MasterLsGod
Oct 16, 2008 10:13 PM
