FS: Action 2MD 6-puck clutch, pressure plate
Old Aug 3, 2013 | 11:04 AM
TurboGoKart's Avatar
Default FS: Action 2MD 6-puck clutch, pressure plate
For sale is an Action 2MD 6 puck clutch and pressure plate for a 92-00 Honda Civic SOHC motor. It had 500 miles on it before I ended up needing to sell the vehicle. You can see in the pictures that the factory grooving on the pressure plate surface is still there. The pucks on the clutch are also barely broken in as you can also see from the picture. Action's description from there website is this:
" Stage 7 Dual Diaphragm Metallic Direct System
Dual diaphragm heavy duty pressure plate
Metallic direct puck style disc (available with 6 puck grooved, 6 puck, and 4 puck discs)
50% increase in pedal pressure
200-400% increase in holding capacity
Aggressive engagement, rapid heat dissipation, and outstanding holding capacity
The unsprung disc is extremely lightweight and provides instant engagement
Engineered for dedicated high horsepower race vehicles"
You can also see the dual diaphragm fingers on the pressure plate. This is by far the best/strongest off the shelf clutch for a 1.6L D-series SOHC motor. You can also use this on a D16Z6 or D16Y8 equipped with a cable transmission. I no longer own a Civic so I have no need for this. Help me clean out my garage and get a fantastic deal on the best clutch for a SOHC! PM or email is key. I will also throw in an alignment tool.
$250 plus shipping
Old Aug 4, 2013 | 03:48 PM
Default Re: FS: Action 2MD 6-puck clutch, pressure plate
Back to page 1!
Old Aug 16, 2013 | 06:07 PM
Make me an offer! Need it gone!
Old Sep 12, 2013 | 05:59 AM
Bump. Price drop to $200! I need this gone!!
Old Sep 14, 2013 | 11:54 AM
You D-series owners aren't scared of this clutch are you?! The pedal feel is NOT bad at all.
Old Oct 14, 2013 | 07:45 AM
EFSedan#6's Avatar
Stock bottom, JRSC and Delta cam....this clutch too much???
dunked dc
Apr 9, 2011 11:06 AM
spets
Apr 18, 2008 11:55 AM
SuicideSlide
11
Aug 29, 2004 01:25 PM
