Chris Miller Racing Camo SFWD part out
We're not looking to trade for anything. Paypal accepted if you send as gift or add 3% to cover the fee.
--BMC pro billet with Moran motorsports 90mm throttlebody. Setup for 8 injectors on the bottom side. $2500.
--Tilton carbon/carbon clutches for b series honda. Two complete units available with hydro throw out bearings. The original 6lbs flywheels.
$3000 for each complete setup.
Also have a new carbon stack, cover and pressure plate. $2000 no flywheel.
--GSR longblock $12k each
GSR blocks with LA sleeves, JE big pin flat top pistons and GRP aluminum rods. All bells an whistles. LS crank with our standard race treatment. ACL race bearings throughout. Step deck and copper oring. Custom ARP head studs.
Cylinder head is a pro top line core, Berylium seats, steel guides, 6mm stem valves on both intake and exhaust. Chambers are pinned. All valvetrain is custom made for these heads and not hard to get. We have spares. All work on head was done by Brad at RLZ. Web pro series cams and rockers are the cam of choice. Engines have t1 trigger exhaust gear on them.
All misc stuff from cam seals, vtec block offs and breather fittings, Valve cover etc is included.
1 engine is brand new and 1 has a few hits. The one with a few hits was torn down completely and checked.
Price is not negotiable.
--Albins Trans and Nitro driveline for sale.
Albins gear stack setup for 26" tire. Liberty bell housing, brand new outter housing that was stress relieved and REM polished . Upgraded bearings through out transmission. Entire Gear stack was REM polished also. Speed factory shift mechanism. Every nut and bolt is brand new from honda.
Nitro driveline, brake rotors and pads are only 3 passes old. Also so are the wheel bearings. Axles are freshly checked out from rob Moore.
$12,500 takes the whole package. Will split for $10k for Trans and $3000 for driveline. This is the NO BS Non-Negotiable price. Not the haggle price.
Please call 631 465 0988 or e-mail us at Sales@CmrParts.com if you want anything of the above!!
ChrisMillerRacing
Sep 21, 2013 01:04 AM
3rdshift
Dec 26, 2009 03:25 PM
