Please help with b16b!!!!
Old Aug 3, 2013 | 01:06 AM
MikeB16boosted's Avatar
Default Please help with b16b!!!!
I have a B16B and won't start i tried jump starting It Still wont start it just try's to turn over once or twice and then stops. So I thought it was the starter took it out and tested it with jumper cables and it works fine but when I but put it back in the car and trying to jump the starter it tries to turn over but will only do it once or twice and after it just clicks as if the starter wasn't Good anymore One more thing the ground to the battery gets really really hot and stars to smoke and when i try starting the car and the car will not even start when we try push starting it. What can it be please anyone
Old Aug 3, 2013 | 01:53 AM
Stevemyster's Avatar
Default Re: Please help with b16b!!!!
check your timing belt
i know your timing could be so off that it wont start. check that out...
Old Aug 3, 2013 | 07:12 AM
aemintgsr's Avatar
Check all the grounds to make sure they have the same voltage as the battery.
Old Aug 3, 2013 | 07:14 AM
Former User's Avatar
Please edit your first post by adding information about your car.
hatcht9x
Dec 20, 2023 09:38 PM
DriveSlowHomie
Jan 26, 2010 10:31 PM
Emmanuel2112
Oct 2, 2009 12:44 PM
EjSex
Aug 17, 2007 08:20 PM
cdn_cd5
Aug 30, 2004 03:44 PM
