91 Crx si distributor
So my dizzy isn't working any more and I'm not trying to pay 300 for one what other car can I get one off of... I tried looking at base and hf but they have 5 pin connectors and I have 7
the HF and SI uses the same plug connectors. yes the si and hf distributors are interchangeable. Yes they have different part number. and yes they work either way.
the DX model will NOT work on either si or hf engine. if you dont want to buy a whole new distributor, you might want to rebuild it. or just replace the worn out part. most likely it is the ignition coil inside the distributor that went out.
