Does anyone make alternative CRX side moldings?
Old Aug 1, 2013 | 06:57 PM
BanzaiBeast's Avatar
Default Does anyone make alternative CRX side moldings?
Hey Guys,
Maybe you know of a company that makes a low profile side molding for CRXs. The only alternatives the net comes up with look worse than OEM. Let me know if you have a source.
The desired look I want is a "Shaved" profile, but not just pulling off the moldings and filling the holes. I think it is the EK model that has the body colored moldings that are smoothed into the body lines. I am probably going to end up molding them from fiber glass.
Putting any graphics on the side of a CRX simply doesn't look right with a black line running across it. Leaving the bottom trim black would look right, I'm not sure about painting the bump rail on the bumpers.
Old Aug 2, 2013 | 05:19 AM
zrickety's Avatar
Default Re: Does anyone make alternative CRX side moldings?
Nobody makes them. Stock moldings or use tape like the guys I see at autox.
Old Aug 2, 2013 | 10:01 AM
In STS we are allowed to remove the mouldings, leaving holes in the sides of the cars open to the elements isn't a good idea, tape looks ratty....even on Sunny-D or The Juice.
You would think with a little craftsmanship and some carbon fiber, someone could mold filler pieces that would look good and not weigh much more than tape. I am probably setting myself up to make a mess, spend some money, and get an education.
Greg
Old Aug 2, 2013 | 10:17 AM
F22Master's Avatar
Why not just make flat metal filler strips? Use thin sheet metal and make long strips and tack them in several places, grind the welds smooth, smooth any seams, and paint it. Shouldnt be heavy at all and seems pretty easy to make.
Old Aug 2, 2013 | 02:36 PM
zrickety's Avatar
Home depot has some nice aluminum strips that would do the job.
Old Aug 2, 2013 | 10:36 PM
dopesk8er87's Avatar
How about painting the molding the same color as the graphics?
ShaffertE36
37
Dec 10, 2013 04:47 PM
beatthisspeed69
May 2, 2006 05:43 PM
bspeed
111
Apr 21, 2006 03:41 PM
missionaryrider
53
Oct 4, 2004 02:56 PM
