CRX Koni Yellow + H&R Race Springs Bottoming out (Help!)
Old Jul 31, 2013 | 01:03 PM
siXUNE's Avatar
Default CRX Koni Yellow + H&R Race Springs Bottoming out (Help!)
Hey folks,
Got Koni Yellows and H&R Race springs installed on my CRX Si a few days ago.
Been driving around here and there to test it and finally went on the highway.
Hit a bump mount on the highway and i felt my suspension bottom out (More so on the front if anything).
Currently they are sitting on:
Middle perch on the fronts
Top perch on the rears
I am not using extended top hats.
I cut 1/4 of the bump stop
The question:
If I raised my front perch setting to the top perch, will that allow a bit more shock travel?
Also, does it matter if which way up the bump stop is installed (I'm using moog strut bellows) and currently the bump stops are sitting inside the dust boot instead of sticking out.
Thanks in advance to any help!
Old Jul 31, 2013 | 02:52 PM
F22Master's Avatar
Default Re: CRX Koni Yellow + H&R Race Springs Bottoming out (Help!)
Yes, raising the perch will give you more shock travel, but you will also be raising the car that amount.
The only way to get more shock travel at the same ride height is extended top hats. They have all 4 on ebay for like $100, thats a pretty good deal.
Old Jul 31, 2013 | 03:58 PM
siXUNE's Avatar
But aren't those from eBay only for adjustable coilovers?
Old Jul 31, 2013 | 04:10 PM
Tyson's Avatar
get rid of those moog strut bellows.
Old Jul 31, 2013 | 04:26 PM
siXUNE's Avatar
Hey Tyson!
What do you recommend for the bump stops aside from the moogs?
Also, would simply cutting more of the bump stop be sufficient enough to stop my bottoming out on my application? Like another 1/4 off?
Old Jul 31, 2013 | 04:42 PM
daveb91's Avatar
The moot strut bellows.....I pretty sure he is referring to the dust boots...not the bumpstops.
Old Jul 31, 2013 | 07:49 PM
siXUNE's Avatar
Which Spring Perch does everyone set their Koni Yellows at?
Also what springs are you guys using?
Old Jul 31, 2013 | 08:41 PM
F22Master's Avatar
No, they are for any shock.
Old Aug 1, 2013 | 11:47 AM
siXUNE's Avatar
I also should mention the rear are sitting a bit higher than the front. Which leads me to believe I can raise the front spring perches to the top as well to balance out the drop height. This should also give me slightly more travel as well as cutting down the bump stops some more?
Old Aug 2, 2013 | 06:56 PM
Vagitarian's Avatar
Pic?? What perhes are you guys refering to
GraphiteMW
Mar 31, 2007 02:50 PM
CRXed
Suspension & Brakes
Feb 14, 2007 09:30 AM
strsi
Suspension & Brakes
25
Sep 2, 2006 01:27 AM
timatao2088
Nov 5, 2005 07:06 AM
PatrickGSR94
Jan 4, 2005 04:22 PM
