B18C5 Part Out: Toda/Skunk2/OEM/A-Sport ITBs/Mfactory/Exedy
Long story short I blew the motor in my ITR and after weighing my options I've decided to go K instead of rebuilding a bigger B. The motor only had 44,461 so all parts will be very fresh. All parts are located in NY and I am willing to ship at buyers expense. More parts will be added as I pull the motor so please check back often.
OEM ITR Torque Mount - $25 (44,441 miles)
OEM ITR power steering reservoir mount $15
OEM ITR Power Steering Cooler and lines - $85
Some B series mount, don't remember what for - $25
K20z1 bare short block. Will only come with what's pictured. It's a replacement block taken out of my brother's RSX. $400 (approx 10,000 miles)
OEM ITR Map sensor - $25 (44,461 miles)
Some RSX mount. Believe it's a possibly for the tranny - $18
Some B series mount, that i also don't remember what for - $25
OEM PRB Aluminum oil pan (bottom one in pic) $50 Has a bung for an oil line but the threads are stripped See pictures. Feel free to try and fix it.
OEM K20a2 power steering pump $50
OEM ITR dipstick - $12
Weisco k20 9.1 pistons with 86mm bore on Manley turbo tuff rods $750. Can work out a deal if purchased with short block
TODA Header SOLD
Intake Manifold SOLD
Starter SOLD
OEM 2000 ITR Cams SOLD
Hasport DCSTK 70A mounts SOLD
Skunk2 Pro 1 Cams and cam gears SOLD
OEM Axles SOLD
OEM Injectors SOLD
Step down harness SOLD
OEM ITR Oil Pan with PW:JDM baffles SOLD
S300 SOLD
OEM ITR flywheel SOLD
ITR Throttle cable SOLD
Timing belt cover SOLD
Alternator SOLD
OEM Mounts SOLD
OEM ITR Main Cover Assembly SOLD
OEM FPR SOLD
RC Injectors SOLD
OEM ITR 4.4 Final Drive SOLD
AEM CAI SOLD
OEM ITR A/C Compressor SOLD
CKF Sensor SOLD
AC Bracket SOLD
Fuel Rail SOLD
Intermediate Shaft SOLD
ITR Transmission SOLD
A-Sport ITB's SOLD
Exedy Clutch and flywheel SOLD
ARP Headstuds SOLD
Transmission Brace SOLD
ITR Torque Mount SOLD
Fujitsubo RM01A SOLD
Shift Linkage SOLD
Side Mount SOLD
Oil Pickup SOLD
Cam Caps and Covers SOLD
OEM cam gears SOLD
TODA Header SOLD
Starter SOLD
OEM Axles SOLD
OEM Injectors SOLD
S300 SOLD
Alternator SOLD
OEM Mounts SOLD
OEM FPR SOLD
RC Injectors SOLD
AEM CAI SOLD
CKF Sensor SOLD
AC Bracket SOLD
Fuel Rail SOLD
A-Sport ITB's SOLD
ARP Headstuds SOLD
Shift Linkage SOLD
Side Mount SOLD
Oil Pickup SOLD
OEM cam gears SOLD
