B16/GSR Frankenstein motor
Looking to start parting out my civic. All parts listed have ~2500 miles on them. The motor was broken in the correct way and not revved past 3k for 1000 miles, that includes no highway cruising. I have most of the receipts for the parts but, the other parts I bought online and do not have a printer. I could probably find some way to show the buyer though.
Motor is from a 95 gsr, I have a copy of the title to prove it is legit.
Freshly rebuilt motor.
b18c1 bottom end, fresh hone, p30 pistons on gsr rods (11:6:1 compression with b16 head)
acl race main,rod,thrust bearings, oem honda piston rings,
oem honda headgasket,
oem honda water pump,
oem honda oil pump
the head is from a b16a, fresh valve guides, seals, gaskets, everything is OEM.
ARP headstuds
the two are paired together with a gates racing timing belt.
Transmission is from a jdm b16a, like butter, but scratches third sometimes
(ALWAYS have used Honda MTF.)
New VSS
Brand new Exedy stage one clutch.
fastline shifter with mugen ****
ITR intake manifold with OMNI power 68mm throttle body (new map and tps sensors)
3 inch intake.
oem honda intake manifold gasket
oem honda throttle body gasket
Hasport motor mounts
new distributor
Mishimoto triple core radiator with an FAL slim fan
street tuned by rcautoworks (chipped p06 on chrome, converted to vtec)
Tri-Y Replica header
Looking for 2200obo COMPLETE, axles/wiring/ecu etc
**still in car so you can hear it run and pull.
Any questions? Text/call is best. 815.582.7931
oem honda oil pump
ARP headstuds
New VSS
3 inch intake.
new distributor
r1de23
Jul 15, 2009 06:30 PM
EJ1_228
Oct 29, 2007 01:41 PM
FredoSP
Jul 6, 2003 05:40 PM
