Code 9, cyp?
Old Jul 31, 2013 | 02:10 AM
superslowcrx91's Avatar
Default Code 9, cyp?
I'm throwing a code 9 for my cyp sensor. I've checked my timing and it is spot on and I have swapped out distributors with a know working one and the code remained. I have checked the wires and the cyp ground and signal both have continuity. Is there anything else that could cause this to happen that I am missing here?
Old Jul 31, 2013 | 05:53 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Code 9, cyp?
ECU maybe?
Old Jul 31, 2013 | 10:17 PM
turn&burn89's Avatar
Originally Posted by 24TEN
ECU maybe?
reset ecu and recheck the code...
Old Sep 30, 2013 | 12:43 PM
Was looking through my threads and though i would update this. When my friend rebuilt the distributor, the rotating piece on the inside that makes contact with all of the sensors as its rotating was upside down (180* out of sync) so thats what was throwing the code 9. Always make sure you put your **** back together correctly.
Old Sep 30, 2013 | 12:54 PM
24TEN's Avatar
PHANTOM MENACE
Glad you updated this thread with the solution
ilikejesus
Jul 2, 2007 06:10 PM
Me2
Apr 11, 2004 03:13 PM
SpoonPL
Sep 27, 2002 07:39 PM
Gump
May 15, 2002 09:00 PM
Jeef
Dec 9, 2001 06:35 PM
