how to check PCV is working
Old Jul 30, 2013 | 11:18 PM
sweesiong78's Avatar
Default how to check PCV is working
I was wondering if there is a way to check the PCV is functioning correctly while it is installed? the service manual says to pinch the hose that goes from the PCV to the intake manifold and hear for a click, but with the engine running its hard to hear with all the noise.
Old Jul 30, 2013 | 11:38 PM
CO671's Avatar
Default Re: how to check PCV is working
Searching is always recommended because:
1) You find your answer quicker
2) Less space on the forum
3) Sometimes, find more info from previous threads .
https://honda-tech.com/forums/acura-integra-6/how-test-pcv-valve-590976/
Originally Posted by JimBlake
Pinch the hose while the engine's running, you should hear it clicking.
I always thought that was kinda ghetto. If you wanna take the PCV valve out, you should hear it rattle when you shake it. There's a little ball on a spring inside the valve.
Clean it if it's full of oil. Blow through it very gently, it should flow pretty easy. Blow through it harder (from the engine towards the manifold) and it should close up so only a little air flows. It shouldn't close completely. Blow the other direction (towards the engine) and it should close completely.
Then after you've done all that, ask yourself if it's worth $8 to just get a new one anyway.
ps...
I just noticed you're from Moscow - welcome. Maybe those parts are harder to find over there... So maybe it's worth it to clean & re-use it.
Originally Posted by Tweakmeister
Shake the PCV valve. If you hear tapping then it is good.
If you hear nothing, then soak the PCV in some gas or other cleaner to dissolve the oil in it.
You are supposed to replace it often, but simply keeping it clean is fine.
Old Jul 31, 2013 | 02:25 AM
NVturbo's Avatar
O.G. triple O.G.
remove the PCV from the engine.
shake it to see if you can here the internal part move.
IF NOT, replace it.
Simple enough people.
Old Jul 31, 2013 | 07:24 AM
Jimster480's Avatar
IF NOT, replace it.
lol yea idk why this guy did a whole search thing. Honestly searching on the forum.
Old Jul 31, 2013 | 02:44 PM
why does H-t always assume posters have not searched?? I asked for a method to check PCV working WHILE installed on the car, and does not involve pinching the hose to hear for click since it is hard to hear for it with the engine running!!!!!
reason I want to check if PCV is working while installed is, incase there is a block somewhere along the system, rattling the PCV while it is off the car would not help!!
Old Jul 31, 2013 | 02:47 PM
and in case if anyone is wondering here is a search result of mine (clearly no one else has asked for a test of PCV while it is on the car with engine running!):
Old Jul 31, 2013 | 05:44 PM
Jimster480's Avatar
yea well u cant really check it while the engine is running you have to pull it out and shake it.
Old Jul 31, 2013 | 06:54 PM
OrangeChrome's Avatar
This thread inspired me to put a PCV in my car to try and fix idle problems. I couldn't really hear the rattle on the OEM PCV Valve (it was VERY quiet), so I put an aftermarket one in there. Kind of a pain, but I pulled it off without pulling the oil filter. Didn't help my idle problems.
Regardless, apparently the Honda OEM PCVs rarely go bad and they tend to work better than aftermarket ones, I might have to pay the $30 I was quoted from Honda.
AutoMaggie
Honda Fit
Dec 7, 2014 09:59 PM
wrsimmons21
Oct 21, 2006 11:22 AM
SergZ
Aug 18, 2003 09:35 AM
mickey513
Nov 17, 2002 01:22 AM
Evil DOHC
Sep 24, 2001 04:36 PM
