Possible problem with clutch/trans
Old Oct 24, 2002 | 10:48 PM
TypeR 8784's Avatar
Default Possible problem with clutch/trans
i just got a 2001 ITR a few weeks ago...i notice once in a while when letting out the clutch on a hill or sometimes even on flat ground it catched MUCH lower than other times, its mostly on a hill though, also sometimes when on a hill or even on flat ground when taking off normal u hear a kind of squeeking sound when letting out the clutch, not just a normal start like if u are rolling backwards a little bit or are on a hill it will do it when more strain is on the clutch, the noise is like metal is rubbing on each other...car still has a warranty just wanted to see if anyone knew of a quick fix or what these could be, car has about 20,000 miles on it, and just an AEM intake, thanx
Old Oct 26, 2002 | 11:30 AM
illusion's Avatar
Default Re: Possible problem with clutch/trans (TypeR 8784)
top
Old Oct 26, 2002 | 02:23 PM
JPP's Avatar
JPP
could be several things...release bearing, release fork, lack of lubrication...if the car is still under warranty it would be much simpler to have them take a look. Probably nothing serious but no easy fix either
m3dia_lab
10
Nov 11, 2004 06:25 PM
SublimeStyles
May 18, 2003 04:14 PM
rockwilda
Jun 19, 2002 03:57 PM
Flux
Apr 16, 2002 08:58 AM
EleanoR
Feb 25, 2002 05:41 PM
