B16 civic sudden bog issues
Old Jul 29, 2013 | 01:52 PM
atmdc's Avatar
Default B16 civic sudden bog issues
I have searched everywhere for a couple days and cant really find anything unique to my situation.
I have a b16 swapped EF. It has ran perfect forever and now all the sudden I was driving on a trip and when I came to a light I felt some slight missing.
When I finally got it parked I noticed if I go wot from neutral it bogs down hard and sometimes stalls. but during driving it runs and pulls fine until Im in neutral or first gear.
spark plugs are new. Oxygen sensors I believe are good. Cap and rotor upon visual inspection look good. wires are fairly new. And I checked to make sure the crank to cam gear timing was aligned. any ideas?? Thanks a lot!
Old Jul 29, 2013 | 08:55 PM
jonGSR's Avatar
Default Re: B16 civic sudden bog issues
Old fuel filter?
Maybe your TPS needs replacing, or to be recalibrated.
Old Jul 30, 2013 | 07:24 AM
jimic87's Avatar
my b16 ef did that turn out my fuel pump was not working like it should not saying that's your issue but my issues and yours where the same
Old Jul 30, 2013 | 10:29 AM
atmdc's Avatar
fuel pump is a walbro and I can here it churning so I dont think thats it. fuel filter could probably use replacing but would that cause stumbling throughout the whole driving range?
Old Jul 30, 2013 | 10:34 AM
jimic87's Avatar
if its clogged it could cause a issue any time if you are unsure on the last time it was replaced then I would definitely go ahead and replace it you will only be helping it either way. Do you have a fuel pressures gauge installed?
Old Jul 30, 2013 | 12:19 PM
atmdc's Avatar
if i were to guess Id say fuel filter is around 30k miles. I have an adjustable fpr with a gauge but the guage needle got messed up from bumpy roads so I dont think its accurate. I went to mess with the car today and it will drive but if I tap the gas from neutral or first it bogs hard then catches up.
idles perfect at 750rpm and highway speeds are fine.
maybe distributor is dying?
Old Jul 30, 2013 | 12:36 PM
jimic87's Avatar
what is you ignition setup ? are you running a external coil?
Old Jul 30, 2013 | 02:49 PM
EFlovin''s Avatar
Sounds like Dizzy/TPS.
Old Jul 30, 2013 | 10:32 PM
atmdc's Avatar
stock ignition setup. maybe tps? i have to find a volt meter somewhere. Although I unplugged it just to see what would happen and it caused a code.
I heard about a tdc sensor in the dizzy?
Old Aug 6, 2013 | 08:48 AM
jimic87's Avatar
did you ever come up with a solution to your problem?
Old Aug 8, 2013 | 06:53 PM
atmdc's Avatar
Yep, I bought a new dizzy on ebay, put it on and the car fired right up and ran perfect! Thanks for all the help and suggestions!
Old Aug 9, 2013 | 04:53 PM
zrickety's Avatar
I was going to say the ignition coil, glad it's fixed.
Old Jan 15, 2014 | 09:43 PM
Accord tuner's Avatar
I hate to sound like a noob, but WTH is a dizzy? Distributor? I'm having a similar problem with the B16 swapped EG I just picked up. Found a screwy TPS, replaced that but still have the bog at WOT.
Old Jan 16, 2014 | 07:43 AM
zrickety's Avatar
Yes, dizzy is short for distributor. If you've done all the tune-up stuff it could be the ignition coil. I had one test good on the meter and it was still bad. Did you calibrate the new TPS?
Old Jan 19, 2014 | 04:28 AM
Yes..55v at closed an 4.55v at wot. The engine was swapped in about 10,000 miles ago. Hsvent done the tune up stuff because that's new. The coil I can believe. I'll check that out.
TiMMDoGG
Jun 4, 2010 01:08 PM
ef9rida
Mar 25, 2009 09:15 PM
Stray
Sep 18, 2007 02:16 AM
guywitaDA
Aug 21, 2005 11:23 PM
MysteryWagon
10
Jul 25, 2003 08:30 AM
