CRX oem radiator ATF cooler fittings ???
Old Jul 29, 2013 | 03:36 AM
99teggsr's Avatar
Default CRX oem radiator ATF cooler fittings ???
Hi all, ive got a substantial ATF leak from one of my fittings that go into the radiator on my 89 DX. Before I go replacing the entire radiator I got to thinking, I may just be able to replace the fitting. Ive got no idea if its possible, but can I remove the oem radiators atf cooler fittings so I can install some plumbers tape and re-install ?? Im trying to save myself from buying a new radiator. Thanks !
referring to the fittings on the bottom of radiator
Old Jul 29, 2013 | 08:29 AM
BLU CIVIC's Avatar
Track Advocate
Default Re: CRX oem radiator ATF cooler fittings ???
pictures i've seen online suggest that you can. i know on the DA radiator i had, they were welded on. your radiator may have removable. only way to be sure is to take a look
Old Jul 29, 2013 | 03:18 PM
99teggsr's Avatar
I ended up removing them , found that the fitting they screwed into was stripped. Ive got it nearly leaky free for now but with stripped fittings it wont last long. IVe got an ebay radiator on the way, just cant find anywhere that sells these fittings seperately.
Old Jul 29, 2013 | 03:32 PM
F22Master's Avatar
jb weld? silicon/rtv sealant?
Old Jul 30, 2013 | 03:49 AM
99teggsr's Avatar
Ive got it leak free for now, but prefer to fix things the right way. dont want to be left stranded with a blown tranny because I cheaped out on some $10 fittings. Just cant find anywhere to buy the damn things separate of the radiator
Old Jul 30, 2013 | 04:10 AM
BLU CIVIC's Avatar
Track Advocate
i suggest hitting up the junkyard
HankYee
Aug 14, 2009 12:58 PM
yz125rider21
15
Jan 7, 2008 11:42 PM
MikesArmy
Mar 7, 2006 08:16 PM
EuN_TeK
Mar 31, 2005 10:36 AM
professorman
Mar 18, 2003 11:43 PM
