92Accord EX ABS bleeding?
Old Jul 28, 2013 | 04:51 PM
BSDMotorSports's Avatar
Default 92Accord EX ABS bleeding?
Almost have this thing ready for its single mom owner.
The brake pedal is bleeding down. It will pump up and then slowly goes to the floor. Once on the floor, no brakes. MC fluid is good an d no bubbling. ABS fluid is good also. Pads good and even. No wheel cylinder leaking. No external leaking at all.
Planning to change the master cylinder, but, the service manual and a tech article I found say that an Accord with ABS can't be bled like standard systems. They both say to take it a dealer or service shop due to the need for special tools required to bleed an ABS system.
What's up with that? Anyone know the detail? I haven't been able to find any tech info.
Thanks.
Old Jul 28, 2013 | 09:39 PM
holmesnmanny's Avatar
Default Re: 92Accord EX ABS bleeding?
https://honda-tech.com/forums/showth...&highlight=abs
starting around post 20 you'll start getting useful info
in your case it's the master cylinder failing...this isn't abs related
masospaghetti
Nov 23, 2016 05:10 AM
bsdubois
Oct 1, 2015 04:16 PM
Nisif
Suspension & Brakes
Jan 14, 2009 11:05 AM
94eg!
Jun 28, 2007 07:14 AM
REDBARON
Nov 11, 2002 04:54 AM
