90 Civic Lx cluster HELP?
My sister has a 1990 Civic sedan and the left turn signal display wont light up when its turned on...Do you guys know what is wrong w/ it? We tried changing the bulbs several times but the bulbs seem not to fix the problem.. Please help thanx in advance....
pull out the cluster and check the wires...here's the diagram.
http://www.geocities.com/twisted91ci...ap_diagram.htm
Get a tester, turn key on, activate left turn signal and test if there's current on the wires...check the back of the cluster too if there's visible signs of a short circuit. If you cant figure it out...it usually cost $50 bux or so for a used cluster from your local wrecking yard.
Goodluck
Goodluck
Thanx alot again...... it is fixed....the problem was that the harness in the back that plugs into the cluster, the wire for the left turn signal wasnt fully in the harness....i Realized it after you gave me the color code wire for the left turn signal...thanks again
[Modified by Eg6xCiViC, 9:05 PM 10/25/2002]
peter96ek
Feb 15, 2008 01:52 AM
whiteef-8
17
Jan 22, 2005 11:42 AM
Got Milk
Jul 15, 2004 03:14 PM
johnzm
Jan 21, 2004 12:24 PM
