first time honda 96 civic ex p1336 code
Old Jul 27, 2013 | 10:58 AM
camaroman.88's Avatar
Icon2 first time honda 96 civic ex p1336 code
hello everyone im new to the honda world grew up with american muscle well i have finally discoverd the import cars are street monsters lol i bought a 96 ex d16y8 with a few bolt on ex cold air header exhaust! the o2 sensor was broke off in the header i got it out and replaced it and reset the ecm and after about 40 miles the check engine light is back on and its a p1336 code for csf sensor intermitten is there any way to solve this without taking the motor apart? best i can tell the wires and connectors are good! thanks in advance for any help!
Old Jul 27, 2013 | 11:52 AM
B_Swapped93's Avatar
Default Re: first time honda 96 civic ex p1336 code
Do understand what that code means/what causes it ?. CKP is the sensor inside the distributer.. CKF is the sensor on the crank shaft. Crankshaft sensor is replacable but i do believe if the one in the distributer is going bad you would have to replace the distributer.
here's a pic
Old Jul 27, 2013 | 01:04 PM
black97civic's Avatar
http://www.2carpros.com/questions/19...ngine-light-97
Old Jul 27, 2013 | 04:17 PM
so i should start with the one in the distributor first?
Old Jul 27, 2013 | 04:18 PM
did you not read my post ? that's the one YOU CAN'T replace...unless you want to buy a new distributer,
Old Jul 27, 2013 | 04:45 PM
yeah i got what you were saying and if it will get the problem fixed then ill replace the distributor i just want to do get the problem fixed so it will pass inspection and emissions! and didnt really want to tear the motor apart!
Old Jul 27, 2013 | 04:50 PM
you won't have to...taking the lower timing belt over off is about all you may have to do which could be a pita but not hard at all.
Old Jul 27, 2013 | 04:55 PM
so its easier to just replace the ckf? and go from there? cause the car runs amazing so im guessing this sensor doesnt really affect much?
Old Jul 27, 2013 | 05:10 PM
it can and can't I've heard of stories where it causes the car to jerk and what not and other where nothing happened at all. have you tried re-setting the ECU ? there's always the chance it's just loose
Old Jul 27, 2013 | 05:28 PM
i disconnected the batterie for five mins and the light went out but came back on after about 40 miles it came back on is there a better way to reset the ecu?
Old Jul 27, 2013 | 05:48 PM
try over night or just 15 mins. you could always take the distributer cap of and see that the leads to it are snug.
Old Jul 27, 2013 | 06:01 PM
ok ill try both and see what happens
Patk
Oct 19, 2013 01:22 PM
camaroman.88
Jul 25, 2013 09:16 PM
handa
Honda Civic (2001 - 2005)
Apr 22, 2007 11:45 AM
stehigs321
Feb 27, 2003 04:58 PM
C1V1C
May 9, 2002 04:07 PM
