2009 Honda ACCORD LX Parts car parting out
Old Jul 27, 2013 | 10:31 AM
ahparts's Avatar
Post 2009 Honda ACCORD LX Parts car parting out
Click here to see full details of this car & its parts on our website!
Email contact
AH Parts Dismantlers
www.ahparts.com
Tel: 877-859-0023
3664 Omec Cir #1
Rancho Cordova, CA 95742
Monday - Friday 9:30am - 5:00pm, Saturday - 9:30am - 2:30pm
- Car # -- Year -- Make & Model -- Version -- Engine Size -- Transmission -
130262009Honda ACCORD 4 DoorLX2.4L5 Speed - Automatic
Car images - Visit our site for large images
Parts Still Available(visit our site for more images)
Image Preview (if available) Item # Part Price
 60377FR/R DOOR,CMPLET -MIRR -TRIM 1 small$700
 60378FR/L DOOR,CMPLET -MIRR -TRIM nice,wh$800
 603794DR RR/R DOOR,CMPLET -TRIM 2 dents$699
 603804DR RR/L DOOR,CMPLET -TRIM nice, whi$699
60382GLOVE BOX tan 77500-TA0-A02ZC$35
60384FR/R DR PANEL CMPLET tan$130
60385RR/R DR PANEL CMPLEE tan$115
60386RR/L DR PANEL CMPLET tan$115
60387RH MIRROR white 76208-TA5-A01$95
60388LH MIRROR white 76258-TA5-A01$95
 60389RH QUARTER PANEL white$625
 60390LH QUARTER PANEL white$625
 60391ROOF CUT$340
60392LH TAIL LAMP,ON BODY 33550-TA0-A01$99
60394FUEL PUMP 17045-TA0-A00$65
60396FR/R SEAT tan cloth, srs sold sep$225
60397FR/L SEAT tan cloth, srs sold sep$245
60398FR/R BELT tan, working$89
60399REAR SEATS ASSEMBLY tan cloth$215
 60400STEERING COLUMN$0
60401DASHBOARD brown / tan,minor dents$199
60402AM/FM/CD RADIO$199
 60403DRIVER SEAT AIRBAG$150
 60404amp,. check$0
 60405check$0
 60408DRIVER SEAT AIRBAG 78055-TA0-A70$150
60409DRIVER ROOF CURTAIN AIRBAG$235
60410RH DASH AIRBAG 77820-TA0-A80ZC$275
 60411RH SEAT AIRBAG$145
60412RH ROOF CURTAIN AIRBAG$235
60414STEERING WHEEL nice 78501-TA0-A81ZA$40
 60415HEAD LIGHT SWITCH$0
 60416WIPER SWITCH$0
60417INSIDE REAR VIEW MIRROR$8
60418R SUN VISOR,tan,nice 83230-TA0-A91ZB$35
6043710 SPOKE 16" HUB CAPS SET OF 4$50
60441AT IGNITION SWITCH + KEY + ECU$225
 60442BACK GLASS tinted black$150
 60443HEATER/AC CONTROL(ON DASH)$85
60444ENGINE,MILES=47k,WARRANTY=6mo$1100
60445AT TRANS,MILES=47k,WARRANTY=6mo$830
 60446HARMONIC BALANCER 13810-R40-A02$39
 60448AT JACK SHAFT 44500-TA0-A00$75
60449RH AXLE 44305-TA0-A00$74
60450LH AXLE 44306-TA0-A00$70
60451FRONT SUB FRAME 50200-TA0-A02$500
 60461RR/R UPPER ARM$40
 60462RR/L UPPER ARM$40
60463RR/R LOWER ARM set of 3$60
60464RR/L LOWER ARM set of 3$60
60468RR/R STRUT N SPRING 52610-TA0-A05$70
 60469RR/L STRUT N SPRING 52620-TA0-A05$70
60472FR/L SPINDLE KNUCKLE$145
60473FR/R BRAKE CALIPER 45018-TA0-A00$60
60474FR/L BRAKE CALIPER 45019-TA0-A00$60
60475RR/R BRAKE CALIPER 43018-TA0-A60$35
 60476RR/L BRAKE CALIPER 43019-TA0-A60$35
 60477RR/R SPINDLE KNUCKLE$115
 60478RR/L SPINDLE KNUCKLE$115
 60479ABS/VSA PUMP/MODULATOR$165
60482EX PIPE A 18210-TA0-A02$150
60484POWER STEERING PUMP 56100-R40-325$115
 60485SOLD WITH #633(SEE IGNITION)$0
60489ENGINE HARNESS,AT 32110-R41-L50$135
60490BLOWER MOTOR$45
60491AC COMPRESSOR 38810-R40-A01$189
 60492EXHAUST MANIFOLD/converter$225
60494AT THROTTLE BODY 16400-R40-A02$85
 60495FR FLOOR CARPET tan 83301-TA5-A11ZD$125
 60496RR FLOOR CARPET tan 83302-TA5-A11ZD$145
60497Steel 16" rim$55
 60498Steel 16" rim$55
 60499Steel 16" rim$55
 60500Steel 16" rim$55
60508RR STABILIZER BAR,$25
 60509MASTER BREAK CYCL,$40
60510POS BAT CABLE STARTER$35
60512FUEL FILLER NECK 17661-TA0-A00$60
60514A/C DISCHARGE HOSE, 80315-TA5-A01$15
60517REAR SPEAKER COVER, NICE, TAN,$40
60522P.S. FEED HOSE 53713-TA0-A04$75
60523CHARCOAL CANISTER 17011-TA0-A01$75
60525CLOCKSPRING 77900-TA0-C11$100
 60526FR/R ABS SENSOR$10
 60527FR/L ABS SENSOR 57455-TA0-A01$10
 60528RR ABS SENSOR 57470-TA0-A02$8
 60529TRANNY MOUNT 50870-TA0-A03$90
 60531FR STAB BAR$40
60542FR/R CRASH SENSOR 77930-TA0-B11$12
60543FR/L CRASH SENSOR 77930-TA0-B21$12
60552DISPLAY UNIT 39710-TA0-305$350
60554CENTER CONSOLE W/ARMREST, DECENT$75
 60555DISCHARGE HOSE 80315-TA5-A01$15
 60557IGNITION COVER, BLK, SMALL SCRTCH$10
 60558AT FLOOR SHIFTER$75
60559YAW & G SENSOR 39960-TA0-A01$200
60571CENTER DASH POCKET, BLK, NICE$0
60628HEATER CORE,$75
60632HEADLINER, TAN, NICE 83200-TA0-A02ZB$150
60634JACK N TOOLS W/FOAM$60
60638P. BRAKE LEVER, BLK 47105-TA0-A03ZA$40
 60639GAS PEDAL 17800-TA0-A01$125
 60641BRAKE BOOSTER$60
60642WINDSHIELD COWL COMPLETE,$125
60643MAP LIGHT, TAN, NICE$75
6064446600-TA0-A83 BRAKE PEDAL$45
 60645DOME LIGHT, TAN 34252-S5A-003ZP$10
 60646WIPER MOTOR$50
 60647LH WIPER ARM$20
 60648RH WIPER ARM$20
 60649LH DRIP SIDE MOLDING 73162-TA0-A01$25
 60650RH DRIP SIDE MOLDING 73152-TA0-A01$25
60651RR ENGINE MOUNT 50810-TA0-A01$30
60653RR ENGINE MOUNT BASE 50680-TA0-A00$75
6065532120-TA0-A01, WIRE HARNESS,$185
 6065936531-R40-A01 ,O2 SENSOR,$85
 6066036531-R40-A01, AIR FUEL RATIO SENSOR$85
 6066150630-TA0-A00, FRONT ENGINE BRACKET$15
 6066250610-TA0-A00, RR MOUNT BRACKET$25
60735INSTRUMENT HARNESS 32117-TA0-A01$115
 60741SHIFT CABLE 54315-TA5-A83$25
60742LH P. BRAKE CABLE 47560-TA0-A01$30
60743RH P. BRAKE CABLE 47510-TA0-A01$30
 60789MASS AIR FLOW SENSOR$45
60870AIR FLOW TUBE 17228-R40-A00$10
 61316FUEL TANK$40
 61395LH VISOR TAN HAS SMALL INDENTS$35
 62215FR/L STABILIZER LINK$0
 62216FR/R STABILIZER LINK$0
 62217RR/L STABILIZER LINK$0
 62218RR/R STABILIZER LINK$0
62621FR/L BLK FENDER LINER, NICE,$0
 62650LH CENTER PILLAR, WHITE$299
 62766IGNITION COIL$20
ahparts
Jul 27, 2013 11:07 AM
ahparts
Jul 23, 2013 06:31 PM
ahparts
Jul 23, 2013 06:29 PM
ahparts
Jul 23, 2013 06:16 PM
