97 civic with oil leak - which torque specs to tighten the head? 1.5? or 1.6?
Old Jul 27, 2013 | 09:00 AM
Walaxvw's Avatar
Default 97 civic with oil leak - which torque specs to tighten the head? 1.5? or 1.6?
I recently rebuilt a 97 civic and the engine code was scratched off of it, come to find out its a 1.5l not a 1.6l it has a 1.6 head on it though, which torque specs should I use to tighten the head? 1.5? or 1.6??? And are they even compatible? Thank you in advance for the help.
Old Jul 27, 2013 | 10:27 AM
crazyhouse2011's Avatar
Default Re: 97 civic nightmare
Use the 1.6. Could you show us a picture doe?
Old Jul 27, 2013 | 10:43 AM
Walaxvw's Avatar
Pic of what just the head or? bottom end is 1.5 top end is a 1.6 just to clarify
Old Jul 27, 2013 | 10:54 AM
The engine. The whole damn thing. And also the bottom end and the head as well. And your valve cover if you can manage.
Old Jul 27, 2013 | 11:44 AM
B_Swapped93's Avatar
what head ?(from what engine)
or what block ? both the number can't be scraped off.
Old Jul 27, 2013 | 12:43 PM
Walaxvw's Avatar
the number on the bellhousing is scrapped off the number on the head is p2j-2
Old Jul 27, 2013 | 12:47 PM
so is the block stamp still readable ? the number on the trans housing would be for the tranny not the block. the head is a 96 EX D16Y8 Auto------P2J-2 stamped.
Old Jul 27, 2013 | 01:08 PM
Walaxvw's Avatar
The engine code on the front plate of the motor is completely gone, Ithink that whoever had the car last blew the original 1.6 in it up and put a 1.5 in cuz it was cheaper? Or that was just more available? And scratched the numbers off because this thing didn't even have a 1.5 option.
Old Jul 27, 2013 | 01:11 PM
black97civic's Avatar
How do you know its a 1.5?
Old Jul 27, 2013 | 01:24 PM
Walaxvw's Avatar
I ordered bearings and rings from the machine shop and they were way to big brought the block to them and they mic'd all the rods and crank and matched them up in their book and said they were messurments off a late 80's to early 90's 1.5, and after Iput it all back together it had an oil leak from the front passenger side of the head gasket..... which is baffling. So Iwas wondering if the head bolts may needed to be torqued to 1.5 stats instead of 1.6.......
Old Aug 1, 2013 | 05:08 PM
Walaxvw's Avatar
Ok so Ifinally got around to putting this new head gasket on it, and low and behold, its leaking oil again.......... I'm beginning to think the head and block are not compatibale even though the gasket lines up on both........
Old Aug 1, 2013 | 05:28 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
I would junk it and grab another motor. If you do not know what you have it is not worth dealing with.
Old Aug 1, 2013 | 05:30 PM
jbpnoman's Avatar
Did you have the head milled, and the block decked? Are you using the original studs, or new ones? Are you following proper torque sequence and pattern? A D is a D, it doesn't matter if it's a 1.5 or a 1.6. People put Y8 heads on D15 blocks all the time. Your oil leak sounds like user error. The scratched off identification, on the other hand, sounds sketchy as hell. The usual reason for scratching off that identifying information is because it's a stolen motor.
Old Aug 1, 2013 | 05:39 PM
Walaxvw's Avatar
The head and block both have been to the machine shop and checked out fine, brand new head bolts, sequenced per instructions on all data for a 1.6l head brand new 1.6l head gasket..... I'm all out of ideas everything mechanichal says its fine but something just isn't right here
Old Aug 1, 2013 | 05:52 PM
knoxrocks222's Avatar
Found a d16y8 on craigslist with 80, 000 miles for 800 you want the link?
Old Aug 1, 2013 | 05:54 PM
My bad its a y7
http://memphis.craigslist.org/pts/3919934782.html
Old Aug 1, 2013 | 05:57 PM
Walaxvw's Avatar
I doubt they would ship it all the way here, thank you for looking though
Old Aug 1, 2013 | 08:30 PM
Lol 800 for that is rediculous.
Old Aug 2, 2013 | 10:15 AM
ya that's pretty steep you can get a b20 for that price and in good shape(more or less). don't do it
Old Aug 2, 2013 | 10:19 AM
Fliptard's Avatar
usually when the engine code is scratched off, it means it was stolen. but not always the case
flashedDc5
Jan 2, 2006 08:08 PM
I_LuvmyHonda
May 2, 2005 06:46 AM
groovinmind
Jun 11, 2004 11:45 AM
isotopesope
Feb 28, 2002 04:52 PM
