Catalytic Converter
Old Jul 26, 2013 | 09:28 PM
vtecpower23's Avatar
Default Catalytic Converter
Just bought a 94 Civic EX and it won't pass smog. Would it be better to buy a direct fit catalytic converter or a weld on one?
Thanks in advance.
Old Jul 26, 2013 | 09:43 PM
black97civic's Avatar
Default Re: Catalytic Converter
Buy an oem converter
Old Jul 26, 2013 | 09:59 PM
Emeraldbomber's Avatar
Yep brand new will be better then potentially welding a clogged or old one in.
Old Jul 27, 2013 | 04:50 AM
94EG8's Avatar
Seagull Management
Direct fit is much easier to work with.
Old Jul 27, 2013 | 10:28 AM
crazyhouse2011's Avatar
Test pipes are a sure-fire way to pass inspection. They're pretty freakin cheap too.
Old Jul 27, 2013 | 10:47 AM
jbpnoman's Avatar
If by pass, you mean fail miserably...then sure.
Old Jul 29, 2013 | 09:49 AM
Thanks for the info.
Seems like my only options for CA smog are magnaflow 50 state-legal direct fit or oem.
I'll go with the magnaflow.
Old Jul 29, 2013 | 10:25 AM
dirty19's Avatar
Ridin Dirty in Cali
Test pipes in california are illegal.
The magnaflow will pass and has a CARB number plate.
Old Jul 29, 2013 | 11:34 AM
Former User's Avatar
Please cease with the bad tech advice. A test pipe won't allow you to pass inspection if your state has emissions tests or requires your car have a catalytic converter (visual inspection).
Old Jul 29, 2013 | 12:04 PM
sweesiong78's Avatar
how about this one from rock auto:
http://www.rockauto.com/catalog/more...522&cc=1168938
Old Jul 30, 2013 | 08:56 AM
Originally Posted by sweesiong78
It's more expensive than the Magnaflow piece but thanks for the info.
Old Jul 30, 2013 | 09:00 AM
I knew a test pipe won't pass emissions. I have a speed3 as well but i don't have experience with catalytic converters.
There's a catalytic converter on the civic currently but i think it's hollow and the stock exhaust is welded on to it. The car is polluting 4x more than a gross polluter.
Old Jul 30, 2013 | 10:52 AM
really, how much is it and where to find it? for my future reference.....
Old Jul 30, 2013 | 10:59 AM
S2BumpsticksGSR's Avatar
Op- make sure you put a stock ecu in when you go to smog. If yours is chipped get a "stock" basemap chip from phearable and use it for the test. I just got through smog by swapping out my chip, putting a new magnaflow 2" piping cat and 2 red bottles of "heet" from parts store. LOW #'s on my JDM GSR...
Old Jul 30, 2013 | 12:06 PM
I just did a quick search on the Eastern Catalytic site and didn't see anything listed for the Civic that's 50 state legal.
The Magnaflow is $250 from most vendors.
Old Jul 30, 2013 | 12:07 PM
I know I should search but how do i tell if my ECU is chipped?
ok thanks the magnaflow is a direct fit?
Edit: Ah ok just saw you have a 94 thats OBD1 thats why its cheaper than our OBD2 CARB cats!
Old Jul 30, 2013 | 12:45 PM
Telecatster's Avatar
Seems like most of Crazy***'s advice is bad advice.
Old Jul 30, 2013 | 12:47 PM
Well, I try not to generalize and instead judge on a case by case basis.
Old Jul 30, 2013 | 01:29 PM
Op- I'm sure someone here has a pic of chipped vs non chipped ecu for reference. Mine failed bad w/performance oriented chip. What does the side of it say? I think yours comes stock w/p28. Unfortunately, those are very common to chip so the only way to know is to open it and look/post a pic. Then we can tell you if it is/isn't chipped.
eMpAtHy
Jul 26, 2008 10:30 AM
neoburi
May 10, 2003 10:33 AM
RegRedTeg
Oct 18, 2002 11:14 AM
