91 accord dx lags in D3 and D4 but not in 1st or 2nd
Old Jul 26, 2013 | 06:12 PM
tanner91accord's Avatar
Icon6 91 accord dx lags in D3 and D4 but not in 1st or 2nd
91 Accord DX. Bought the car for $650, needed transmission, bought tranny for $225, my dad (worked on cars for 10 years+) and I put the tranny in. The car seems to take of in 1st and 2nd fine, but in D3 and D4 seems to lag acceleration. One person told me to check all cables make sure the connection is clean, (done, did not work). Another told me to check every fuse in the car(yet again did not work). i can upload pictures and stuck, just tell me what i need to take a picture.
[IMG][/IMG]
Old Jul 27, 2013 | 06:42 AM
Lost Again's Avatar
Default Re: 91 accord dx lags in D3 and D4 but not in 1st or 2nd
Are you sure this is a trans issue or an engine issue?
You just got it, are the tune up items all up to date?
Jump the service connector (behing glove box) and check for any stored codes in the ECU/TCU.
Old Jul 27, 2013 | 10:23 AM
I don't believe it is a motor problem, the motor runs smooth, and with the old transmission that was in the car, it was slipping, that was the only issue, that's why it was replace, and when the old one was in the car, it would accelerate like no ones business. Now, With the new transmission, it only gets up and goes when its in 1st or 2nd. And i have receipts that show new spark plugs, wires, power steering pump, alternator, and my father did a valve cover gasket.
How do i go about jumping the service connector.
Old Jul 27, 2013 | 11:34 AM
Lost Again's Avatar
Go to the FAQ and look for the "how to" on the codes.
Not sure but you could also check the throttle control cabel - runs from the tb to the trans - to be sure it has the proper adjustment/movement.
Old Jul 27, 2013 | 11:55 AM
I have already attempted to read the codes, but i have not been able to find the ECU. I found two goldish in color, metal boxes with wires going to them. I believe the smaller one is the ECU but, no lights on it to code it. (Sorry I am still learning about cars)
Old Jul 27, 2013 | 12:09 PM
HonBeer's Avatar
I think the ECU is under the right passenger seat. That is where it was on my 1988 lxi accord. There is a light on the ecu itself that blinks the codes.
Old Jul 27, 2013 | 02:04 PM
from 88-91(i beleive) it is under the passengers feet. (again i beileve not sure exactly) That info i got off this website http://www.troublecodes.net/honda/ again. not possitive. My car is a 91 Accord DX.
Old Jul 28, 2013 | 03:16 AM
Lost Again's Avatar
This would be wrong information. On the 3rd gen Accord (86-89), the ECU is under the DRIVERS seat.
OP- you have a service connector. Once jumped, turn the key to "on" and watch the CEL light for engine codes.....the D4/"S" (if you have this option) will flash if there are trans codes.
Old Jul 28, 2013 | 02:08 PM
Heres what i tried. i jumped the connector, and my "s" light blinked 8 short blinks. I can take video and show if that will help figure out the problem. I dont not have knowledge to fix myself. nor do i have very much time. i have till august 8th.. i need it fixed.
Edit::
I found a posting, the guy had similar problem in a 91 Accord LX. The last posting said it would be the o2 sensor. But their was no posting saying the problem was solved, could that be whats faulty. I have notice that after the "test pipe" it has exhasut leak all the way to the end of the exhaust.
Old Jul 29, 2013 | 08:29 AM
Lost Again's Avatar
8 from the TCU (trans) is an issue with Shift Solenoid B. Check the wires to it - pay close attention to the inside of the connector. Then test the solenoid.
Old Jul 29, 2013 | 11:14 AM
THANK YOU!! ill check that!! and ill post if that solved problem.
Old Jul 30, 2013 | 03:01 PM
Still did not fix the problem. even replaced with known good solenoid. but no go. what should be my next step?
Old Aug 10, 2013 | 04:27 PM
UPDATE: Turns out, that the man at the salvage yard I received the transmission from, gave me a 90(I believe) transmission, with a 91(I believe) torque converter. My dad and I started on it this morning at 7:30AM and finished at about 2-3PM with the new correct transmission and new correct torque converter. Everything is working great now! Thanks for help though!
bpatriz
Sep 4, 2007 05:09 PM
sachse_s2000
Aug 25, 2006 11:06 PM
jakedoza
Apr 22, 2005 07:45 AM
