Clutch problems, not engaging when cold.
97 Civic DX 5 speed
Hey guys, first time posting here. In the span of about a month, my clutch first started sticking to the floor. The big issue that just arose is when I first turn on the car. It feels as if my clutch isn't engaging at all. I pump it, try turning the car off and on again. Eventually once the car has been on a few minutes it starts engaging. It still feels like I'm barely able to shift, but it at least works. I'm very much a novice to a lot of car repairs, but in doing research I'm thinking about ordering a new master cylinder. Thoughts?
It's probably been around 75k miles since the Gear Oil has been drained and filled.
So the little resovoir attached to the Master Cylinder just has a tiny bit of liquid on the bottom. So I'm thinking that's likely the problem, god I'm a noob. What fluid do I put in there?
I see the slave cylinder. I haven't seen any evidence of leaks. Since I've had this car I havent added brake fluid to that resovoir though. Once I add the fluid, should i take any other steps?
Civicfanatic_09
Jan 20, 2010 08:58 PM
Honduh Uhcord
Oct 15, 2007 08:29 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
ludewithanh22
Jul 9, 2005 07:47 PM
