97 Civic HX - running pig rich
Old Jul 25, 2013 | 08:03 PM
wolfhalen's Avatar
Default 97 Civic HX - running pig rich
Hello Honda Tech
My civic has always run pig rich since i got it
The previous owner had installed a header and straight exhaust. When i finally started trying to get the car running right i noticed the 5 wire plug for the o2 sensor just hanging there with nothing plugged in!!!!
The fault code originally was p1167 02 heater failure
The secondary sensor was already installed in the back of the header
So i bought the (very expensive) wideband sensor and welded a bung on to install it.
Well the car ran much better for a while but seemed to learn itself back to the extremely rich state.
now it reads p1169 primary ho2s high input - online i found this means rich condition well duh
additionally i get a p0117 coolant temp circuit low input - replaced the coolant sensor, no change
anyway i would appreciate any suggestions on getting this thing dialed back to acceptable fuel consumption thanks
Old Jul 25, 2013 | 09:24 PM
Former User's Avatar
Default Re: 97 Civic HX - running pig rich
Check the O2 sensor and ECT sensor wires.
Which ECT sensor did you replace? Post pictures.
Has the engine been swapped or is there a D16Y5 under the hood?
Old Jul 25, 2013 | 09:36 PM
wolfhalen's Avatar
Thanks for the reply!
Ok i will check the wires in the daylight
i replaced the sensor at the front of the head where the upper radiator hose is located
and yes there is the original d16y5
Old Jul 25, 2013 | 09:40 PM
If you want the engine to run as intended (lean), you must fix the O2 sensor and ECT codes. Did you reset the ECU to verify that both codes repeat?
You should also clean the EGR valve and the EGR chamber in the intake manifold. Both are probably heavily clogged with carbon.
Old Jul 26, 2013 | 03:56 AM
grumblemarc's Avatar
The Grumpiest
So no catalytic converter? I'm thinking you need to revert to the original hardware.
Old Jul 26, 2013 | 01:13 PM
wolfhalen's Avatar
Yeah no cat
i cant find anything wrong with wiring as yet although i didn't tear into it to far because i have to go to work
im wondering unless i got a bad o2 sensor brand new (its an ngk) if maybe my ecu is shot
Old Jul 31, 2013 | 07:32 PM
wolfhalen's Avatar
i have had no luck finding another fault
an educated guess if the ecu is bad? is there a procedure to determine for sure?
Old Jul 31, 2013 | 09:23 PM
Are you testing the wires with a multimeter?
Old Jul 31, 2013 | 10:11 PM
wolfhalen's Avatar
yeah and its a pita
i cant believe even in open loop it should be this rich my bumper is covered in black soot
compression is 180 across the board
Old Jul 31, 2013 | 10:14 PM
Originally Posted by wolfhalen
yeah and its a pita
Details? Do you know how to do the electrical tests indicated in the diagram?
How did you test the ECT wires and ECT sensor?
Old Jul 31, 2013 | 10:40 PM
wolfhalen's Avatar
i know how to do them its just a royal pain to do the second test between the ecu plug and o2 sensor plug
(edit: i had to unwrap the harness and move the wires and plug to reach where the o2 sensor is now installed.)
i will give it another shot tho (i work an extreme amount of hours)
in your opinion could it run rich enough to foul plugs with a bad primary sensor?
Old Jul 31, 2013 | 10:44 PM
The combination of the two codes is causing the engine to run very rich. You want to minimize driving the car until you fix both codes.
Old Jul 31, 2013 | 10:54 PM
wolfhalen's Avatar
ok i will do my best for the second part of that electrical test
i really cant wait to buy another wideband sensor
thank you for the help
Old Aug 1, 2013 | 06:44 PM
wolfhalen's Avatar
ok i dug into it and found that my green/black wire for sensor ground had popped out of the o2 sensor connector. thought i was in the clear with that !
moved on and found the temp sensor and vtec pressure switch plugs were swapped yikes
ok hooked neg bat cable up again and fired her up ran much better
p0117 code gone
1 minute later p1169 returns
so i go through the tests you gave me and the wires check out both the 5v on the white wire and continuity to the 16p connector for the sensor ground
yay im left to buy another f'n wideband
i bought the brand new ngk sensor which i would have expected to be good
so im wondering if having the sensor ground unplugged coulda fried it, seems possible
Old Mar 11, 2015 | 09:45 PM
wolfhalen's Avatar
I would like to post an update - to help any who might search
So due to previous help here and a bit of luck i found the NTK o2 sensor i bought was junk!
To anyone with an primary o2 sensor problem on a manual HX you need to buy the Denso 2345052 -wouldnt use Bosch or NTK only the denso
Anyway, someone swapped various parts on this car including the intake with a non EGR one, and i come to find out, the injectors !!
I noticed when i plugged my scanner in that my fuel trims were reading -35% at idle WHOA! after some research found that 240cc injectors were installed on the damn thing
Ok so i replaced those with the proper ones and its running almost perfect now
However my fuel trims go more positive now like up to 14% while cruising
so im gonna check for vacuum leaks
Changed the intake for a d16y8 one with an egr valve, egr code comes on after a while though. wonder if the ports on the head could be clogged? cuz the manifold isn't
Old Mar 12, 2015 | 06:01 AM
tony_2018's Avatar
Fish Twig
There is no d16y8 with an egr port.
Old Mar 12, 2015 | 08:51 AM
chrysler kid's Avatar
So you converted your rare lean burn vtec motor into a plain old run of the mill ratted out rice mobile with 115hp of bumble bee fury?
That extended 02 sensor for the header is not going to be giving the ecu the accurate readings. Put a stock exhaust manifold and cat back on that car immediately
So you took off the y5 intake manifold? Why
Old Mar 14, 2015 | 01:03 PM
wolfhalen's Avatar
did you read my post chrysler kid? The car came with various parts swapped out i didnt rice out anything.
Where in my post does it say that I tried to hot rod this car?
Im still getting wild fuel trim readings with the proper injectors installed .. i suspect im on my own with that
I could install a cat on the car, im not going to spend the money for a complete oem system
I dont believe that would solve my fuel trim issue since it corrects from the primary sensor
Old Mar 14, 2015 | 07:06 PM
Moving the primary 02 sensor further down stream with the aftermarket header compromises the sensors readings.
You have a header on the car and you're missing a Catalytic converter, or its been moved further down stream.
Y5 manifolds are the only ones with egr valves
Old Sep 8, 2015 | 04:20 PM
Gator417's Avatar
Not everybody has the passion for the Y5/HX as you do CK. I opted for the Y5 because I desperately needed an engine and that was available. I opted for a Y8 intake and exhaust manifolds because I didn't want to run 2 cats on my car or mess with EGR. I opted for a P28 ECU because that's what I had that would work. I opted for a Z6 throttle body because that's what's needed for a P28 to run a Y8/Y5. Now it runs pretty good and has a better power band than the Y8 & Z6 I had in it before. When I figure out how to get the VTEC-E to kick in, I'll be set. Just because something is rare doesn't make it valuable or collectible or even worth rescuing.
Good luck and please keep us informed on your progress.
Gator
Old Sep 8, 2015 | 08:05 PM
tony_2018's Avatar
Fish Twig
wth....2 cats? On which civic do you know of that runs 2 cat converters?
Old Sep 9, 2015 | 01:12 AM
Gator417's Avatar
None, and I don't want to be the first.
The stock Y5 exhaust manifold has a cat built in to it. My car already has a cat in the stock location (for an LX). Using a Y5 manifold would have given me 2 cats. That's also why I didn't run the stock ECU (P2N). I would have had to extend my O2 sensor wiring, and figure out the EGR plumbing as well. Not to mention, the car from which it came had the CVT & I wasn't sure how the ECU would like me doing the gear selecting. I was in a big hurry to get all of this done, so I went with a simpler route. I'm very happy with the results and I'll post some details as soon as I get the final tuning (TPS, ignition timing & idle reset) complete.
Gator
Old Sep 9, 2015 | 01:25 AM
eghatch9295's Avatar
Stancetard Hate Monger
the y5 can be an interesting motor to play with, but you do need some tuning done. roller rockers aside, the head is still very much an oddball. id almost feel better running it on a p06 until you're able to play with some basemaps.
Old Sep 9, 2015 | 06:40 AM
tony_2018's Avatar
Fish Twig
Gator
Than you obviously don't know what you're typing, using a y5 manifold does not mean you run 2 cats.
edit: fyi the d15b 3 stage vtec had regular headers with the o2 sensor near the lower part of the radiator, cat converter was separate.
Old Sep 9, 2015 | 12:56 PM
Gator417's Avatar
"Than (sic) you obviously don't know what you're typing, using a y5 manifold does not mean you run 2 cats.
edit: fyi the d15b 3 stage vtec had regular headers with the o2 sensor near the lower part of the radiator, cat converter was separate." tony_2018
Yes Tony, I do know what I'm typing, you just don't understand what you're reading.
I didn't say anything about a D15B or 3 stage VTEC. Its a totally different setup as the Y5.
FYI, the Y5 had a cat integrated into the exhaust manifold. Its one piece, doesn't unbolt or come apart. My car already has a cat on the tailpipe, so if I were to run BOTH the stock cat AND the integral cat on the Y5 manifold, that would make 2 cats. Get it?
"the y5 can be an interesting motor to play with, but you do need some tuning done. roller rockers aside, the head is still very much an oddball. id almost feel better running it on a p06 until you're able to play with some basemaps." eghatch9295
The Y5 head is the same casting as the Y8, same valves & everything. The valvetrain is quite unique though, as is the way in which it functions. Perhaps it would be more fun to play with if it weren't my DD and only transportation besides my LPCs. I haven't a clue how to change basemaps or any of what goes on inside the ECU & I don't have a P06 lieing around. It runs great on a a stock, virgin, unmolested P28 though, so there's really no point.
Wolfhalen,
Sorry if we've hyjacked the thread. I don't know much about this bastard Y5, but I'm happy to share what I've learned. Good luck.
Gator
