00 civic lx automatic with CEL code
Old Jul 24, 2013 | 11:37 PM
The1990CRX's Avatar
Icon6 00 civic lx automatic with CEL code
Just bought a 2000 Honda civic lx 4 door automatic for my girlfriend... 250,000 taken very good care of. exterior 9/10, interior 10/10. We live in AZ so we do emissions and all. There was no CEL on the car when we bought it. did a full tune up on it, wipers, etc... well 40 miles goes by and i get a p040 code for the new CEL. I cant find anything on this. anyone have any ideas? And yes, that is the full CEL code it gave.
Old Jul 25, 2013 | 12:05 AM
jbpnoman's Avatar
Default Re: Need some help with new sedan
Check your power steering fluid, and reset the ECU. See if the code returns. If it doesn't, great. If the CEL comes back on, pull the code again, but use the jumper trick instead of a scanner. Info is in the FAQ's sticky.
Old Jul 25, 2013 | 03:31 PM
The1990CRX's Avatar
I cleared it and it has yet to light back up. PS fluid looks good. Thanks for the heads up!
Old Jul 25, 2013 | 03:32 PM
teamXteg's Avatar
Icon4 Re: Need some help with new sedan
incase you werent able to find it man
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Jul 25, 2013 | 05:00 PM
Former User's Avatar
P040 is not a code. There's one digit missing.
Old Jul 26, 2013 | 01:03 PM
The1990CRX's Avatar
Thanks for the heads up folks. Tested it with a Snap On OBD tester and got some really good information. Needed new o2 sensor. Would work 98% of the time but would not report 2% of the time. Why the CEL was lit. Still did not fix my other problem that I didn't mention, the Idle. I have done a near full tune up. Changed cap, rotor, wires, plugs, airfilter. Have the fuel filter, will do that tonight. But after the car warms up it idles at about 250-500, very low, to where I think its going to die. This does it when car is in gear, park and neutral when it warms up. Car is 100% stock automatic D16Y7. Next step is to clean IACV and adjust idle if necessary. Any one else have $0.02?
Old Jul 28, 2013 | 10:26 PM
turn&burn89's Avatar
Default Re: 00 civic lx automatic with CEL code
iacv and adjust cable.
civicb16eg
Jan 5, 2010 01:23 PM
Shaynepolevault
Honda Civic (2001 - 2005)
Nov 16, 2008 09:43 AM
bigsyke
Jun 3, 2008 09:41 PM
tofun
Sep 12, 2005 02:57 PM
