OBD2 injectors in a6 manifold?
Old Oct 24, 2002 | 08:10 PM
4potnick's Avatar
Default OBD2 injectors in a6 manifold?
I just got some injectors out of a 2000 civic dx. It is my understanding that i can use these in a a6 manifold running obd1. I have a p28 and other goodies to make this work on my dx with a y8 head. I just want to make sure everything is going to match up.
Old Oct 24, 2002 | 09:27 PM
Iceycrx's Avatar
Default Re: OBD2 injectors in a6 manifold? (4potnick)
If you already got the y8 head on then it should plug right in, unless u havent done the wiring from the dx to the new setup.
Old Oct 25, 2002 | 04:44 AM
4potnick's Avatar
Default Re: OBD2 injectors in a6 manifold? (Iceycrx)
I am doing a obd1 conversion. I just want to make sure that the obd2 injectors will work running a obd1 ecu inside a a6 manifold.
Old Oct 25, 2002 | 04:53 AM
EP3_05's Avatar
Yeah they will work fine all 92-up civic injectors are saturated style injectors. Doesn't matter if they come from an OBD1 or 2 car they are all 240cc saturated style injectors.
BryanM.
Mar 10, 2011 02:31 AM
roycivic92
May 26, 2010 11:22 PM
ShinobiLude
Aug 15, 2005 11:40 AM
EJ2-Fluffy
11
Jan 13, 2005 03:01 PM
aesthetics82
Apr 2, 2003 05:39 AM
