gsr head,egt gauge,JE pistons, Z10 oil pan, motec engine harness
Motec m4 or m48 harness $350
Autometer egt gauge new part number 4344 $100
95 gsr ported head in running condition. All parts are stock in head. $400
used je 83.5mm 10-1 b series pistons with used rings. In runnable condition $200
Z10 dry or wet sump oil pan. Used for running an aftermarket oil pump. You should be able to use with a stock oil pump and pickup too? I am not sure? Also comes with a oil pump delete if you want to run the dry sump. $200
themazdak
Apr 19, 2008 07:27 AM
