93 Del Sol - Need help installing an aftermarket keyless locking system
Old Jul 24, 2013 | 07:08 AM
Warwalker4's Avatar
Default 93 Del Sol - Need help installing an aftermarket keyless locking system
Hello everyone,
I'm trying to install a remote to my central door locking system. It's located in the passenger side door as shown in the picture below.
the colors of the driverside lock are black and red
the colors of the passenger side lock are white/red and yellow/red
these are the wire colors on the locking system:
and the receiver colors:
this plug should go into this box (which is the wireless receiver):
and then the userguide:
That's all i have as userguide.
problem is, all the colors are different and this might be because my car is Japanese and these color schemes are European.
Shortly said, I really have no idea how to install this.
Would be great if anyone can help.
(oh and please dont comment on the speakers, the previous owner installed it and I'm not happy with that either.)
thanks in advance,
Randy
Old Jul 24, 2013 | 07:42 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Del Sol Central lock help needed.
Don't know how you plan to do this without a wiring diagram. Google and download the FSM.
Old Jul 24, 2013 | 08:21 AM
Warwalker4's Avatar
Hi, Thanks for replying.
this is the only wiring diagram i could find with some information about doors. I hope it's enough information.
http://efshare.com/?s=WNBM2X
this is the PDF file i found.
Old Jul 24, 2013 | 08:30 AM
Former User's Avatar
96-97 Del Sol?
Can you post individual enlarged pictures of the installation instructions? It's difficult for me to read.
Old Jul 24, 2013 | 08:56 AM
Warwalker4's Avatar
Nope it's from '93 but i can't find any wiring for that one.
the individual pictures:
I hope they're clear enough now.
Old Jul 24, 2013 | 09:01 AM
angrysmileyface's Avatar
Default Re: 93 Del Sol - Need help installing an aftermarket keyless locking system
Half the instructions look like they are for adding the power pullers and what not. Realisticly you need the FSM and just find the wires that are tied to the switch that locks and unlocks the car door and tie them to your keyless entry module. I know from experiance in adding a CR-V's keyless entry and retrofitting my civic to use it. (I had to add a few more wires to the door harness in order to grab the dome light to make it work). Also as an FYI, some 5th civics cant define if del sols do or not, have a security connector in the foot well for the OEM alarm which allows you to lock and unlock the doors.
Old Jul 24, 2013 | 09:15 AM
Does your car currently have a stock power lock system and all the stock lock harnesses?
First post, second picture from top - does this picture show the connector for your car's stock driver-door lock actuator?
Warwalker4's Avatar
Yea... well which wires should connect which, that's my problem. I could pop it between the wires of the drivers side switch. because that also switches the passenger door. But I have no idea which wires to connect.
Old Jul 24, 2013 | 09:17 AM
Warwalker4's Avatar
Everything in the passenger door is stock, except for the driver door... previous owner has been messing with that trying to install an alarm, that's why those wires are black and red.
Old Jul 24, 2013 | 09:23 AM
Have you removed the alarm? How is/was it wired into the system?
Do the power locks currently work properly?
Old Jul 24, 2013 | 09:24 AM
What exactly is shown in this^ picture?
Old Jul 24, 2013 | 09:27 AM
Warwalker4's Avatar
Everything works like it should. Except for the alarm itself.
in that picture you see the stock central lock box connector with the wire colors.
Old Jul 24, 2013 | 09:37 AM
Oh, I see.
The lock control unit was moved from the driver door to the passenger door, right?
The connector shown with six wires is the connector for the moved lock control unit, right? if so, two wires (Grn/Red and Grn/Wht) are missing and you have a Blu/Red wire not seen in the stock plug. See diagrams of stock 92-95 Civic lock circuit and control unit pin out below.
Old Jul 24, 2013 | 09:40 AM
Warwalker4's Avatar
Well, that's the weird part. It looks like it was not moved to the passenger door. If i remember correctly then the alarm is only connected to the drivers side door and the passenger door just follows up the switch command.
the alarm installation could be the cause of wires missing. But i really have no idea where to start then.
Old Jul 24, 2013 | 09:46 AM
Are you game for an experiment?
Old Jul 24, 2013 | 09:47 AM
Warwalker4's Avatar
If the experiment commences in this weekend. I need it tomorrow.
Old Jul 24, 2013 | 09:48 AM
Not sure what's you're saying.
Do you have a multimeter?
Old Jul 24, 2013 | 09:52 AM
Warwalker4's Avatar
No, I don't have a multimeter but i could get one tomorrow or this weekend.
Old Jul 24, 2013 | 09:53 AM
Post back when you have a multimeter and you're ready to do some wiring tests.
Old Jul 25, 2013 | 02:14 PM
Warwalker4's Avatar
Okay, i've got a multimeter and I can start testing in 9 hours and 50 mins. That will be 10 AM for me.
Old Jul 26, 2013 | 11:06 PM
Warwalker4's Avatar
Please let me know what wires to check and what to do then.
Old Jul 27, 2013 | 01:46 AM
b16lewis's Avatar
here
http://www.the12volt.com/installbay/...ailm/1063.html
Old Jul 27, 2013 | 01:47 AM
Warwalker4's Avatar
Yea... awesome site, but my car isn't in the list.
Thanks anyways
Old Jul 27, 2013 | 09:05 AM
b16lewis's Avatar
93 del sol is right there on the web site
http://www.the12volt.com/installbay/...ailm/1062.html
Old Jul 27, 2013 | 09:59 AM
^nice link
