transmission wont go into gear
Old Jul 23, 2013 | 09:43 PM
armmata's Avatar
Default transmission wont go into gear
i was driving down the road in our 95 accord ex 4 cylinder vtec automatic car is running great a little slip once in a while but nothing big figured need a flush so anyway going down the road been driven for about an hour and i come up to a light come to a stop and light turns green hit the gas and nothing engine just revs up no movement at all nothing i ended up pushing it out of the road dose any one have any idea
Old Jul 23, 2013 | 10:33 PM
jdowen2's Avatar
Default Re: transmission wont go into gear
I guess punctuation is a lost art. Have you checked the fluid level?
Old Jul 23, 2013 | 11:23 PM
MAD_MIKE's Avatar
MM Gruppe B
Mileage?
Turn the engine on and place it in every gear for 10seconds to charge each circuit. Place back in park, pull AT dipstick, wipe off, reinsert, pull dipstick and note where the level is. To work properly the trans needs to be within the hash mark.
What color is the fluid?
Does it smell burnt?
Turn the car off, turn the car to ON(not start) when all the lights come on momentarily does the CEL, D4, and ABS also light up for a moment and then go off? If not you will need to replace the bulbs to be able to verify if there are any codes.
If not you will need to replace the bulbs to be able to read the codes, if any, are stored.
If the fluid has never been changed, and the car will momentarily work but then stop working, most likely the sump is clogged with crud. You can try draining the fluid, and refilling to see if that removes some sludge from the pickup. If the trans has 250Kmiles, hell I would even throw a bottle of SeaFoam Trans-Tune into it to help with any build up.
This is the ONLY additive I would add to a H4A, or any other transmission for that matter.
Old Jul 24, 2013 | 06:03 PM
armmata's Avatar
fluid has been changed, and did check codes i am getting a 7 & 8 code. I believe codes are for the shift solenoid.
Old Jul 24, 2013 | 06:42 PM
MAD_MIKE's Avatar
MM Gruppe B
http://techauto.awardspace.com/transmission.html
Old Jul 27, 2013 | 08:24 AM
armmata's Avatar
Ok how about this my transmission cooler lines are not warming up with the rest of the transmission
aperezd
Jul 24, 2017 10:18 PM
2002accordguy
Nov 30, 2015 04:57 PM
littledude56
Dec 30, 2008 01:02 AM
Kabato48
Dec 16, 2008 07:19 PM
alencarfr
Dec 7, 2003 12:05 PM
