91 Accord with low idle
Old Jul 23, 2013 | 08:19 PM
Wolly1987's Avatar
Default 91 Accord with low idle
I have a 91 accord with low idle. I recently did a timing belt and water pump change no problems there, but prior to changing out that stuff i had a low idle with a surge. The surge was pretty random, I would start the car and it wouldnt surge unless i moved the vehicle and let off the gas and then the idle would stop once the car was warm. Im assuming it was the FIV and i tightened down the outer ring on that. I havent heard any surge yet, but i havent driven much. I still have a low idle though. I have cleaned the idle air control valve and the throttle body with no success on that yet. Im going to bleed the coolant tomorrow and see if that helps at all. But any further troubleshooting processes before i have to throw a new idle air control valve in it? I dont see any other options yet.
thanks
Old Jul 24, 2013 | 12:00 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 91 Accord with low idle
How low? What RPMs are you seeing?
Old Jul 24, 2013 | 12:46 PM
Wolly1987's Avatar
around 400-500 rpms with no ac on.
Old Jul 24, 2013 | 05:38 PM
Wolly1987's Avatar
I also forgot to mention that i pulled off one of the vacuum hoses and the rpm increased to about 900 rpm's so im pretty sure that it isnt a vacuum leak.
Old Jul 24, 2013 | 05:48 PM
Mishako129's Avatar
You very well maybe reading the tach wrong. The first thick white line is 500 rpms, then after that the small lines are 100 rpms.
Old Jul 24, 2013 | 05:54 PM
MAD_MIKE's Avatar
MM Gruppe B
Have you checked your base ignition timing? If it is slightly retarded it will lower the idle rpm.
Davesmit
Mar 24, 2019 11:27 AM
91Accordkid
Jun 9, 2015 04:35 AM
portlandkidd157
Jan 20, 2011 11:00 AM
sun_zinc
Jul 13, 2008 01:19 PM
mean_1
Jul 30, 2004 06:30 PM
