92 civic cx hatch help ! (wont crank!)
Hey guys whats up. I just got this 92 cx hatch a few weeks back and I just put my b20 in it. I have a 95 si hatch wire harness on the motor and the after swaping the motor in, hooking all the plug/ lines up I go to start it and when I turn the key over it does absoluetly nothing, not even a click from the starter. The dash lights do not dim whien trying to start either. I hear the fuel pump priming and the main relay clicks. The ecu light on the cluster comes on for the two seconds then goes off like normal. Although I do here a slight click coming from the engine bay fuse box area when I go to turn the key to start the car then turn the key to the off position. All my lights work.. dash lights, blinkers, headlights, brakes, high beams etc..
The battery is oem honda that I bought like three weeks back and when I had this swap in my coupe about a week and a half ago, the starter, battery and alt all worked just fine. All the fuses in the engine bay are good and same with inside the car from what I remember.
Im not too sure what the heck is going on because ive never come across this problem with any previous car or previous swaps ive done in the past. So if you guys might have an idea please help me figure this out.
sorry for the novel but I thought Id be as descriptive as I could.
Thank you for viewing, Billy
Ive looked them over but I will go over them again and grind more on the frame to get to metal. Oh and since the battery was just sitting in my coupe for like a week with out bein hooked to anything, I put it on a trickle charge.
My ground currently consist of...
trans to chassis
thermo grounds
and the battery to the chassis
Am I missing any?
I put new stoppers in the clutch and the brake pedals befor putting the motor in. tried starting the car while pushing the clutch pedal in and tried w.o pushing down on the pedal.. nothing
but Im really thankful for the imput youve done so far. Keep em' coming!
I just dont know where to go from here.
The clutch pedal can have 2 switches - upper and lower. The lower one is the cruise control switch and the upper one is the starter switch. Did you put a rubber stopper in the upper one? Is the switch properly adjusted to press on the rubber stopper?
yeah i had no idea the pedals could have two switches. But yes i found my last new rubber plug and reached up and popped it in. And it seems to be functioning correctly. Ive started it numerous time already.
You get the plugs at your local honda dealer parts department. I work at my Honda dealership in the parts. They are like 2$ each. But your issue sounds electrical to me. Might be best if you start your own thread. Good luck to you.
go ahead and lock this one up mods!
94CivicHatchGSR
Jul 30, 2014 07:55 PM
Somalie187
Dec 29, 2012 09:24 AM
civicdelsol33
10
Jan 6, 2011 08:20 PM
xsaxisx
Jun 10, 2009 11:01 AM
vacantskies88
Mar 30, 2009 05:07 AM
