b16a obdo pr3ecu need help please!!
my ecu is giving me codes 14 and 23 iac valve and the knock sensor i am going to replace the knock sensor tomarrow but every time i try to drive the car it loses complete power when i push the pedal to the floor if i just drive it normal nothing happens the swap came with an msd ignition is this a problem
You probably have them switched, the plugs are the same. Check that the knock sensor wire is going to the correct pin (B19) at the ecu.
BILLisCHILL
May 8, 2008 06:40 PM
T_Rex
10
Sep 10, 2002 08:38 PM
