Accords 94-95 Gauge Cluster Tech
Old Jul 23, 2013 | 12:04 AM
NZXTInerTia's Avatar
Default Accords 94-95 Gauge Cluster Tech
People following my build thread probably noticed I just picked up a new tac to replace my faulty one in my 94 EX. Pulled apart my dash and cluster tonight and noticed the circuit board on my current tac has a larger and wider circuit board then the tac I pulled from a 94 EX Wagon (automatic as is my cluster). Was there two different gauge clusters in the 94-95 Accords? I will regardless be pulling the entire cluster out of the Accord Wagon at the junkyard tomorrow, that being if it has the standard three plug I/O interface as mine. Serial numbers on the two gauges read 186 HR-186 and HR-187 indicating some difference, along with my cluster reading #2 on the identification sticker HR-186 being the dominant numbers throughout my cluster. Perhaps the Wagon cluster was different in some way? The junkyard Wagon year, trim, transmission (original auto tranny as per mine is a conversion/unrelated), etc. is identical to the Accord that I own. Although I found it interesting that both tac's had the same three pin/screw interface. Ground, Ignition, signal, just in a different layout.
Left is the one from the Wagon HR-186 and right is from my CD7 HR-187.
The stamped HR-187 on the back panel of the cluster, also with speedometer, temp, fuel, etc. all with the matching HR-187.
Manufactured in 1994 as is my HR-186 tachometer from the Wagon. Pay attention to the number two, perhaps they made two different gauge clusters? Hopefully the entire Wagon HR-186 cluster plug interface matches my current one. Then I'll just yank the entire thing.
Old Jul 23, 2013 | 01:35 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Accords 94-95 Gauge Cluster Tech
Your original Tach looks like my '95s Tach circuit board, Wagon may be an earlier build with 1st year bastard bits that your '94 may have been a later model with mid year updates.
The only other difference that the wagon cluster/board will have over the coupe is warning lights. Wagon/Sedan have four doors with the additional two rear door warning lights. Coupes do not have this. I do not know if the Wagon may also have some rear wiper signal or rear fluid reservoir low fluid check, if that is even applicable.
Remember on reassembly do not over-tighten the fuel gauge screws, hell just use your pinky to put the screws back on... damn Honda
Old Jul 23, 2013 | 03:58 AM
Fitz Williams's Avatar
10 Year Member
I hate to hear that. I just assumed all 94 gauge clusters were the same and bought a JDM one from Japan or Hong Kong, don't remember which. It's a nice cluster, reads in km and all, but now I wonder if it will even fit. I guess the only way is to pull mine and see.
Old Jul 23, 2013 | 10:11 AM
Even the gauge faces don't seem to have the same mounting screw locations. At least that's a sure fire way to determine clusters without yanking it I guess!
Just to clarify~
My CD7 cluster. HR-187
Wagon cluster. HR-186
Old Jul 23, 2013 | 08:15 PM
Turns out myself working on my distributor and my tachometer going out the same night was just a really horrible confidence! She finally works! I also was able to verify my tune with VTEC at 4k, 2step at 4k and 6k. Rad!
http://distilleryvesper1-17.ak.insta...1fa414_101.mp4 Woo!
Made a sweet fridge magnet out of the old one too. lol
Old Jul 24, 2013 | 12:13 AM
MAD_MIKE's Avatar
MM Gruppe B
Old Jul 24, 2013 | 12:35 AM
Originally Posted by MAD_MIKE
XD
Stop the Beast
Honda CR-V & Element
Sep 24, 2012 12:26 PM
dela4220
Dec 11, 2009 07:48 PM
GOLDBERG
May 23, 2004 06:52 PM
jdmintegra1994
Nov 7, 2003 06:22 AM
Veil_Side_
Feb 19, 2002 10:41 AM
