Header installation price range
Old Oct 24, 2002 | 07:17 PM
iam7head's Avatar
Default Header installation price range
How much did you guy paid for to get your headers installed?
how long it will take?
Old Oct 24, 2002 | 07:57 PM
1genCL's Avatar
Default Re: Header installation price range (iam7head)
why not do it yourself?
Old Oct 24, 2002 | 08:20 PM
WhoNeedsVtec's Avatar
Default Re: Header installation price range (1genCL)
install should be no more then 50 though. IMO
Old Oct 24, 2002 | 08:37 PM
iam7head's Avatar
Default Re: Header installation price range (WhoNeedsVtec)
why not diy?
I did my high flow cat before but I dont have all the tools.
so any tips to diy that sh_t?
Old Oct 25, 2002 | 04:06 AM
Stew Pidasso's Avatar
A decent exhaust shop will be able to do it in about an hour. 50-60 bucks like WhoNeedsVtec said. It would be much easier on a lift but you can try it yourself. Oxy/Acetylene torches would make your life 100 times easier.
Old Oct 25, 2002 | 07:00 AM
smokin rubber's Avatar
Default Re: Header installation price range (Stew Pidasso)
get a new exhaust manifold gasket,, it's easy
Old Oct 25, 2002 | 07:06 AM
Gennady's Avatar
New User
Default Re: Header installation price range (smokin rubber)
Put front of car on jackstands
Remove heatsheild
Remove any useless metal pieces that may restrict access
Remove 02 sensor(s)
Bust your *** trying to get the 3 cat bolts off
Use socket extention to get to the 3 bolts that connect to header to downpipe off
Undo 9 bolts that hold header primaries to the head
Apply anti-seize to 02 sensor
Reverse process
Old Oct 25, 2002 | 02:36 PM
iam7head's Avatar
Default Re: Header installation price range (Wont be beat)
how tight I should tighten it?
I kind felt the bolts are coming losse after i put the cat
by myself.
Old Oct 25, 2002 | 03:23 PM
ArchAngel Sabastian's Avatar
New User
by myself.
torque wrench to spec...or
lift the front of the car.. start it, if the cat bolts arent tight enough you will feel the exhaust leak same with your exhaust manifold...carefull not to burn your self
Old Oct 25, 2002 | 05:42 PM
n0 iNTegRiTY's Avatar
itd be about $60. but my opinion, it would be more convenient (price-wise) is doing it yourself
Old Oct 25, 2002 | 05:48 PM
iam7head's Avatar
Default Re: Header installation price range (RAF LTD. 2)
damn...ten freakin' days and my header still in midde west.(just called FATX today)
Old Oct 25, 2002 | 08:14 PM
Nick H's Avatar
New User
there really isn't any way to do a header install wrong actually...seriously, just lift the car and the rest is self explanatory (making sure you remove and install from the underside of the car)...it's just nuts man, it's just nuts....(and a few bolts too)
Old Oct 26, 2002 | 04:54 PM
iam7head's Avatar
Default Re: Header installation price range (Nick H)
I took off the nuts for stock header today, it is so fu_king easy compare to installing high flow cat byself.
here are my question.
the stock header is also two piece(accord 02, 4cyl) can i use the gasket
between the two piece? coz they doesnt come with one.
btw auto zone have gasket too?
the aftermarket header have the o2 sensor near where the cat is.
I bypassed my o2sensor for my high flow cat. can i just switch those two sensor?
BTW I am gonna work on it as soon as the header cool off.
Old Oct 26, 2002 | 10:35 PM
iam7head's Avatar
twisted another torque wrench head...fu_king weak sauce taiwanese sh_t!!!
Old Oct 27, 2002 | 01:15 AM
New User
wd 40 is your friend soak the bolts in it homeslice..
reuse gaskets..prolly...
kmart tools...*sigh*
impact wrench...uh..you have a air compres.. right?
Old Oct 27, 2002 | 01:28 AM
iam7head's Avatar
just so ******* pissed!! I have no tool that can do the ******* job right.
the extension bar bented!! I have no ******* way get that sucka out.
damn..I am getting some real tools tomorrow.
The set I have is 9.99 from k mart. they twisted up so easy.
I also ordered impact wrench...
Old Oct 27, 2002 | 02:22 PM
iam7head's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1870872322
is that impact wrench good? or just another ebay junk?
Old Oct 27, 2002 | 02:35 PM
New User
most likely junk.... eh you should be able to do this with hand tools homeslice.
if you take the o2 sensor housing bolts off and the primary to head bolts off you should be able to pull it off and not mes with the middle man bolts.
Old Oct 27, 2002 | 02:49 PM
Desslok's Avatar
Default Re: Header installation price range (ArchAngel Sabastian)
The bolts on my cat were so tight that my impact gun didn't work. I had to use a 2 foot breaker bar. I was under the car and basically had to bench press the thing. You should be able to buy or rent a breaker bar at Sears, Pepboys, autozone, home depot, etc. The torque wrench I got at home depot for about $50 and works really good. It does 0-100 ft. lbs. The key is the more you can jack it up the better. I used my $20 Pep boys jack stands, kept jacking it up and putting blocks of wood under my jack and got it to the max the jackstands would go.
Old Oct 27, 2002 | 05:28 PM
iam7head's Avatar
Default Re: Header installation price range (sp)
finally gave up and used air tools..
rent them at local garage.
Here the problem. It shake like **** when i step on the gas..
and it sound like a 1975 mustang with no muffler no cat.
I am thinking of taking off the high flow cat.
Old Oct 28, 2002 | 05:00 AM
flrdaccrd's Avatar
doit yourself for nothing
Old Oct 28, 2002 | 08:18 AM
4doorH22's Avatar
IIRC just need 14, 12 (and maybe 10 mm for the heat sheild) sockets and wrenches.
If you don't own a rachet/socket/wrench set yet get one.
Old Oct 28, 2002 | 01:34 PM
EuRoBrO's Avatar
You can do it!
Old Oct 28, 2002 | 05:24 PM
iam7head's Avatar
Default Re: Header installation price range (EuRoBrO)
I am getting more tool this weekend..including impact wrench....I am think about it..
btw the header installation is done...my back hurts...Jk
so is it normal to see white smoke when it frist start up?
since all the WD40 mess and new gasket?
Old Oct 28, 2002 | 05:27 PM
iam7head's Avatar
and one more question, the header really give alot of extra heat under the hood.
The fan blows more often and longer so it's a normal thing or it something bad?
